jasonshort
Member since June 2019
Post by jasonshort on Jun 22, 2019 16:02:05 GMT -5
Post by rockjunquie on Jun 22, 2019 17:49:39 GMT -5
I think you are looking for the word trivet. Looks like intarsia. He was very good at it, too. It involves a lot of precise work. You can search here for more threads about intarsia, including how it is done.
hummingbirdstones2
Vince A., 1958-2023
Member since August 2018
Post by hummingbirdstones2 on Jun 23, 2019 9:12:42 GMT -5
Yep, rockjunquie is right on the mark on all counts. I've never had the patience for that. Your uncle's work was very impressive.
jasonshort
Post by jasonshort on Jun 23, 2019 15:52:01 GMT -5
Post by rockjunquie on Jun 23, 2019 17:11:50 GMT -5
Well, I guess you got it in yer blood.
jasonshort
Post by jasonshort on Jun 23, 2019 19:21:47 GMT -5
Hey can someone take a closer look at those black lines onthe trivet? They are not the same size. Is there a possibility that it is some kind of liquid that is poored between the rocks like a resin that turns black?
Post by RWA3006 on Jun 23, 2019 23:00:11 GMT -5
That's really fun! What a great tie to your great uncle you have there. I think he used a resin to pour into the gaps after he glued the onyx pieces in place. Then he probably put a final polish on the entire surface to finish it. It's easy to add pigment to many resins while you're mixing them to prep for the pouring process.
NRG
Member since February 2018
Post by NRG on Jun 24, 2019 0:39:48 GMT -5
Hey can someone take a closer look at those black lines onthe trivet? They are not the same size. Is there a possibility that it is some kind of liquid that is poored between the rocks like a resin that turns black? Could simply be a black epoxy. But also could be little pieces of obsidian or other black stone. The green sphere is standard glass. Nice work he did!
jasonshort
Post by jasonshort on Jun 24, 2019 7:19:36 GMT -5
Thanks, my aunt said it was crystal, but It does look like glass.
Post by rmf on Jun 24, 2019 7:41:26 GMT -5
what you are calling white onyx is Silver Lace Onyx, I can't tell from the image if the black is a rock or a resin. If it is something like Black Onyx or another black rock (obsidian, Jade) are the ones that come to mind. They would be harder than the onyx. if it is a resin it is probably easily scratched with a pocket knife, where the black stones listed will not scratch.. For intarsia I would guess a black stone.
