Post by glennz01 on Oct 18, 2019 9:56:54 GMT -5
Have a 24 inch saw, what are the 2 motor wheel sizes you use to get the speed right?
Post by rockpickerforever on Oct 18, 2019 10:09:13 GMT -5
Have a 24 inch saw, what are the 2 motor wheel sizes you use to get the speed right? Assuming you mean pulley sizes? It depends. What is the RPM of he motor? What material are you cutting?
Post by roy on Oct 18, 2019 10:18:25 GMT -5
2" on the motor 10" on the arbor i beleive
Post by rockpickerforever on Oct 18, 2019 10:47:41 GMT -5
Post by glennz01 on Oct 18, 2019 15:17:08 GMT -5
This was an old ho.ebuilt 1950s or so unit it had a 30a 2hp motor going from a 4 inch to a 4 inch and 12 inch feed but the motor was too large for my circuits at home so I put on my 1hp motor which couldn't spin, it has currently a 2 or 3 inch on motor and I swapped the 12inch to the heavy 12 inch pulley. Thinking I should get a lighter and smaller 10 inch pulley and maybe a larger motor pully?
Post by Lapidaryrough / Jack Cole on Oct 18, 2019 15:44:43 GMT -5
Old Highland-Park, Motor 4'' saw blade arbor 10'' for the blade, and 2'' on the screw feed belt to worm gear three speed reduction 6'' x 5'' x 4'' for bull gear.
rockpickerforever nice to see the link on post. Jack. old blade slower rpm. the new mk blade rpm speed change. i run natch blade 3800 SFM - 4200 SFM. which is 600 rpm with 4'' - 10'' motor 1750 rpm.
I use over kill on motors. old fran & tom saws, 1956 24'' baldor motor.3/4 hp. i changed it to farm duty sealed. 1 hp.
!982 24 highland-park same 3/4 hp, changed to 1hp.
New motor / not the same \on continuous duty.
Post by glennz01 on Oct 22, 2019 17:59:23 GMT -5
Can't seem to find a 6, 8 and 10 in pully with 3/4 inch id pully. Any good source for inexpensive? Nothing on eBay or amazon
Post by Lapidaryrough / Jack Cole on Oct 22, 2019 20:49:52 GMT -5
NRG
Member since February 2018
Post by NRG on Oct 23, 2019 21:19:42 GMT -5
Can't seem to find a 6, 8 and 10 in pully with 3/4 inch id pully. Any good source for inexpensive? Nothing on eBay or amazon Tractor supply? Ace hardware? Surplus supply? eBay?
Post by glennz01 on Oct 25, 2019 20:18:14 GMT -5
Can't seem to find a 6, 8 and 10 in pully with 3/4 inch id pully. Any good source for inexpensive? Nothing on eBay or amazon Tractor supply? Ace hardware? Surplus supply? eBay? Found a few.... you forget I'm in Alaska I think...... we finally just got a sonic if that says anything.... yet to get a tractor supply
NRG
Post by NRG on Oct 25, 2019 21:51:52 GMT -5
glennz01I know you are Alaskan. I assumed tractor supply but expected the others. eBay is your friend for lots of stuff I am sure.
Post by glennz01 on Oct 26, 2019 12:30:47 GMT -5
glennz01I know you are Alaskan. I assumed tractor supply but expected the others. eBay is your friend for lots of stuff I am sure. Maybe I should rephrase to haven't been up here lol..... now I just have to find lots of mineral oil. As the tank in this saw is going to take a bit
QuailRiver
Post by QuailRiver on Oct 26, 2019 23:47:16 GMT -5
Getta Grip
Member since November 2016
Post by Getta Grip on Nov 30, 2019 23:46:47 GMT -5
I don't know if you figured out what you needed to know, but here's a little bit of information.
To find your blade RPM, divide the motor RPM by (driven pulley diameter divided by the drive pulley diameter) for example;
the motor is 1740 RPM The driven pulley is 10" The Drive pulley is 4.5"
So 1740/(10/4.5)=783 RPM
To calculate surface feet per minute, multiply PI times the blade diameter times the driven shaft RPM divided by 12.
For example;
a 20" blade times PI (3.14) times the driven shaft RPM = (20 x 3.14 x 783) /12 = 4097.7 sfpm
A great source for inexpensive pulleys and belts is Surpluscenter.com. The have an online catalog and will mail you a free hard copy catalog if you want one.
Post by glennz01 on Dec 4, 2019 20:43:38 GMT -5
well, saw cuts but oddly enough the blade binds when the rpm is in the optimal range for speed. i put the 12 inch on again, put a flightly larger pully on the feed. still super slow though but least i can cut. just have to figure how to speed up the rpm without binding.
Current blade rpm is about 420 r less
Post by woodman on Dec 4, 2019 22:08:15 GMT -5
I will check my 24 and see what the blade arbor is running at tomorrow, it's dark and scary out there right now!! The only time it quit cutting was when I let the blade get dull.
Post by RocksInNJ on Dec 4, 2019 23:01:59 GMT -5
I will check my 24 and see what the blade arbor is running at tomorrow, it's dark and scary out there right now!! The only time it quit cutting was when I let the blade get dull. Careful. In your neck of the woods, Bigfoot could be out there getting his rocks off with your saw. Lol
Post by woodman on Dec 5, 2019 10:48:52 GMT -5
I got places in my woods that I never venture into, You never know what lurks there!
Post by woodman on Dec 5, 2019 17:56:25 GMT -5
I braved it today, even got fire going in my shop. cutting 5 inch Brazilian agate as I type.2.5 in pulley on motor 10 in on arbor showing a blade RPM of 460. I do not know what the feed rate is. My 24 is an old Highland Park 24 in saw. cuts great.
Post by roy on Dec 6, 2019 12:15:05 GMT -5
I will check my 24 and see what the blade arbor is running at tomorrow, it's dark and scary out there right now!! The only time it quit cutting was when I let the blade get dull. lol dark and scary lmao thats funny old man
