Post by knave on Jan 23, 2020 5:31:48 GMT -5
Running in 500AO now.
whyofquartz
So, Africa is smaller than I expected...
Member since December 2019
Post by whyofquartz on Jan 23, 2020 12:41:39 GMT -5
Looking good
Post by knave on Jan 23, 2020 12:47:21 GMT -5
Post by Deleted on Jan 23, 2020 12:48:05 GMT -5
Starting to look like a dish of candy!
Post by miket on Jan 23, 2020 12:53:22 GMT -5
Getting there- those should turn out great!
Post by captbob on Jan 23, 2020 13:06:50 GMT -5
Question (or suggestion) if you don't mind... Why are you using so much ceramic media in 180/220 (never heard of 180/220 grit before) when there are plenty of smalls in the batch? You could have added maybe 10 + more rocks instead of the ceramics. I can see using ceramics once past 220, but not so sure it is necessary in the coarse/medium steps. Adding more rocks gives you more options to cull out the pieces you aren't pleased with later on when you then do add ceramics.
Your rocks there have shaped up nicely. Just sayin' more rocks = more better!
Post by knave on Jan 23, 2020 13:20:56 GMT -5
Good point captbob. I had these shaped in the little 3 lb HF tumbler it was all I had ready to go into the vibe and I couldn’t wait to get started. Good advice though.
Post by Fossilman on Jan 23, 2020 15:30:08 GMT -5
Also that metal screen will damage the material(It streaks the rocks..) always use plastic...
Post by knave on Jan 23, 2020 15:40:15 GMT -5
I appreciate the tips.
whyofquartz
Post by whyofquartz on Jan 23, 2020 15:53:20 GMT -5
Also that metal screen will damage the material(It streaks the rocks..) always use plastic. good to know before I built or bought any of these prospecting sieves. time to look up nylon contractor cloth
Post by knave on Jan 23, 2020 15:58:45 GMT -5
Yeah I just got it yesterday, thought it was the cats meow. Hmm. Maybe just for rough.
Post by joshuamcduffie on Jan 23, 2020 20:25:03 GMT -5
I have the same screens, love them and haven’t noticed any problems from them. I also have a plastic colander I got from Goodwill for a dollar. It fits pretty well in a 5 gallon bucket.
Post by aDave on Jan 23, 2020 20:31:18 GMT -5
Also that metal screen will damage the material(It streaks the rocks..) always use plastic. good to know before I built or bought any of these prospecting sieves. time to look up nylon contractor cloth Not so on the cloth thing. If you're so inclined, I've used my same plastic colander that I've had for a couple of years and used for all stages. I got my colander at Target. Just make sure the holes are small enough to contain any material you want to keep.
Post by knave on Jan 23, 2020 21:11:07 GMT -5
I really like this screen maybe I will coat it with rubber spray
Post by joshuamcduffie on Jan 23, 2020 21:36:09 GMT -5
Post by knave on Jan 23, 2020 21:50:31 GMT -5
Benathema
Member since November 2019
Post by Benathema on Jan 23, 2020 22:13:05 GMT -5
Think an old cloth over the screen would work well enough for letting sludge wash through?
I picked one of those up recently since it was sturdy, fit the bucket well, and the sidewalls helped contain and funnel everything. It has only seen coarse ground rocks so far, but that's about to change.
Otherwise, looking good!
Post by knave on Jan 23, 2020 22:16:40 GMT -5
Thank you!
Post by knave on Jan 23, 2020 22:22:07 GMT -5
(never heard of 180/220 grit before) I just A$$umed the Polly Plastics stage 2 was same as Shawns vibe stage 1. Silly of me. Thanks for pointing it out.
Post by RocksInNJ on Jan 23, 2020 23:23:23 GMT -5
I really like this screen maybe I will coat it with rubber spray Just throw a plastic colander from the dollar store on it and you’re all set.
