Post by MsAli on Feb 2, 2020 20:49:06 GMT -5
I just had to show this one off because it's just so cool Was going through one of the auction buckets and found this slab Blue Binghamite
Blue
Feb 2, 2020 20:56:11 GMT -5
Post by rockjunquie on Feb 2, 2020 20:56:11 GMT -5
Nice!
Blue
Feb 2, 2020 21:12:01 GMT -5
Post by RocksInNJ on Feb 2, 2020 21:12:01 GMT -5
Lookin good!
Post by pauls on Feb 2, 2020 21:13:01 GMT -5
Those bluey coloured areas aren't asbestos are they?
Post by MsAli on Feb 2, 2020 21:16:12 GMT -5
Those bluey coloured areas aren't asbestos are they? Not entirely sure.
Blue
Feb 2, 2020 21:17:21 GMT -5
via mobile
Post by Pat on Feb 2, 2020 21:17:21 GMT -5
New to me. Really like the right side in first photo. Can’t tell if left side is the skin or not. Thanks.
Post by rmf on Feb 2, 2020 22:10:23 GMT -5
looks like Pietersite so if it is not solid then it is asbestos. Think of tigereye as fossil asbestos (metaphorically since it was never alive).
Post by MsAli on Feb 3, 2020 7:15:46 GMT -5
looks like Pietersite so if it is not solid then it is asbestos. Think of tigereye as fossil asbestos (metaphorically since it was never alive). What do you mean by "not solid" ?
Post by Fossilman on Feb 3, 2020 10:57:49 GMT -5
Also with asbestos, handle with care and wash hands after you handle it, mask up when you are working with it... Nice material you have there..
Post by Deleted on Feb 3, 2020 12:54:43 GMT -5
Those bluey coloured areas aren't asbestos are they? Unless memory is failing more than usual, not in binghamite. I recall the fibers in binghamite being quartz replacement of parallel needles of iron-rich minerals (such as hematite). In the Minnesota Silkstone (as well as portions of binghamite) the less flashy shimmery areas are replacement of goethite needles that weren't lined up in as parallel formations. As in tigereye, where the asbestine crocidolite-riebeckite fibers are partially or completely replaced by quartz, in binghamite the original hematite, goethite, etc. needles have dissolved and been replaced (though there can be some pits where quartz didn't entirely replace the original minerals). That's quite a colorful piece for binghamite! (ETA: here's a link to the USGS description)
Blue
Feb 3, 2020 13:04:51 GMT -5
Post by RickB on Feb 3, 2020 13:04:51 GMT -5
Pretty rock. It has character.
Blue
Feb 3, 2020 13:07:52 GMT -5
Post by miket on Feb 3, 2020 13:07:52 GMT -5
Can't wait to see what you do with this, it's beautiful.
Post by MsAli on Feb 3, 2020 13:51:15 GMT -5
Those bluey coloured areas aren't asbestos are they? Unless memory is failing more than usual, not in binghamite. I recall the fibers in binghamite being quartz replacement of parallel needles of iron-rich minerals (such as hematite). In the Minnesota Silkstone (as well as portions of binghamite) the less flashy shimmery areas are replacement of goethite needles that weren't lined up in as parallel formations. As in tigereye, where the asbestine crocidolite-riebeckite fibers are partially or completely replaced by quartz, in binghamite the original hematite, goethite, etc. needles have dissolved and been replaced (though there can be some pits where quartz didn't entirely replace the original minerals). That's quite a colorful piece for binghamite! (ETA: here's a link to the USGS description) Everything I read agrees with the above as well. I cannot see anything about it containing asbestos
Post by rockjunquie on Feb 3, 2020 13:55:39 GMT -5
Unless memory is failing more than usual, not in binghamite. I recall the fibers in binghamite being quartz replacement of parallel needles of iron-rich minerals (such as hematite). In the Minnesota Silkstone (as well as portions of binghamite) the less flashy shimmery areas are replacement of goethite needles that weren't lined up in as parallel formations. As in tigereye, where the asbestine crocidolite-riebeckite fibers are partially or completely replaced by quartz, in binghamite the original hematite, goethite, etc. needles have dissolved and been replaced (though there can be some pits where quartz didn't entirely replace the original minerals). That's quite a colorful piece for binghamite! (ETA: here's a link to the USGS description) Everything I read agrees with the above as well. I cannot see anything about it containing asbestos I learn something new with almost every post from @rocks2dust . Love it!
Blue
Feb 3, 2020 14:14:18 GMT -5
Post by MsAli on Feb 3, 2020 14:14:18 GMT -5
So do I
Blue
Feb 3, 2020 21:03:59 GMT -5
MsAli likes this
Post by hummingbirdstones on Feb 3, 2020 21:03:59 GMT -5
Me too! He's like a walking encyclopedia.
Great look rock, Ali. Looking forward to seeing what you make out of it and how it polishes.
hummingbirdstones2
Vince A., 1958-2023
Member since August 2018
Post by hummingbirdstones2 on Feb 3, 2020 21:41:01 GMT -5
Yep, @rocks2dust nails it - as usual.
That blue Binghamite is a rare find. You should be tickled pink.
Blue
Feb 3, 2020 21:54:00 GMT -5
Post by MsAli on Feb 3, 2020 21:54:00 GMT -5
I'm am pretty dang happy about it.
Post by rmf on Feb 6, 2020 7:31:48 GMT -5
looks like Pietersite so if it is not solid then it is asbestos. Think of tigereye as fossil asbestos (metaphorically since it was never alive). What do you mean by "not solid" ? I have/had a piece of blue tigereye that was about 2" thick and on one end the asbestos fibers were not completely cemented. You could actually move them back and forth.
Blue
Feb 6, 2020 7:38:21 GMT -5
via mobile
Post by knave on Feb 6, 2020 7:38:21 GMT -5
Friable
