Post by Condor on Feb 9, 2020 15:36:41 GMT -5
What do you use when tracing the shape of a cab? I use an aluminum scribe, but it is very thin and hard to see when I cut cab.
Post by stardiamond on Feb 9, 2020 15:42:37 GMT -5
Number 2 pencil and remark when required.
Post by Condor on Feb 9, 2020 15:45:00 GMT -5
Number 2 pencil and remark when required. Won't it come off with the water as you are forming the cab?
Post by stardiamond on Feb 9, 2020 15:54:50 GMT -5
I go around the template multiple times to build up the graphite. After using the trim saw, I redraw and then again if the line fades.
Post by Deleted on Feb 9, 2020 16:28:14 GMT -5
I've had good results using a fine-line paint pen. Doesn't wash off or fade, doesn't stain the material, and easily scrapes off with an Xacto blade if you change your mind. You can get them at stationery, craft, and online stores (just make sure you are getting the finer tips). I'm also using the same pen to re-mark the backs of slabs in my personal collection - I've had too many adhesive labels fall off and other marks smudge off or fade. The aluminum wire you're using is good (and cheaper), but harder to draw with and harder to remove if you want to change the mark. I like the white paint as it is easy to see on any color of rock (even white), but any bright color would probably do.
Post by joshuamcduffie on Feb 9, 2020 20:30:58 GMT -5
I bought a carbide tipped scribe, but agate just laughs at it, aluminum nail works good. Stay away from a sharpie marker on translucent or transparent material. Even acetone and time on the flat lap couldn’t completely get sharpie off of blue lace agate.
Post by rmf on Feb 10, 2020 5:21:11 GMT -5
recently I have been using an ultra fine tip sharpie
Post by knave on Feb 10, 2020 7:45:33 GMT -5
Post by joshuamcduffie on Feb 10, 2020 8:42:22 GMT -5
I read somewhere online to use a paint pen, like from Michaels or a craft store, and that it would scrape off the back with a razor blade. Haven't tried it yet.
Post by Fossilman on Feb 10, 2020 10:44:13 GMT -5
I use Sharpies "Fine", buy them at Walmart in two packs, I uses silver, gold and black...
Cab marker
Feb 10, 2020 10:46:20 GMT -5
via mobile
Post by knave on Feb 10, 2020 10:46:20 GMT -5
I read somewhere online to use a paint pen, like from Michaels or a craft store, and that it would scrape off the back with a razor blade. Haven't tried it yet. Post 5?
Post by joshuamcduffie on Feb 10, 2020 11:03:15 GMT -5
I read somewhere online to use a paint pen, like from Michaels or a craft store, and that it would scrape off the back with a razor blade. Haven't tried it yet. Post 5? Yup, that was probably it.
rads
Making clay each day!
Member since April 2018
Post by rads on Feb 11, 2020 10:17:36 GMT -5
I use old aluminium knitting needles that have differing tip widths. Typically, I decide in pencil and mark to cut with aluminium. Each Knitting needle can be made into at least 3 scribes.....I bought a bundle of them at a garage sale for .50 cents.
Post by fishenman on Feb 11, 2020 20:02:26 GMT -5
I use 0.125" Brass rod. I sharpen it to a point and do a heavy scribe with my template. I use sandpaper to erase my marks if needed.
julieooly
Post by julieooly on Feb 13, 2020 17:44:51 GMT -5
Stay away from permanent Sharpie in any color. The silver and gold ones work great but they're super thick tips. I use a regular graphite pencil most of the time, no the water does not wash away the lines but if you're cutting with oil that will take it off. I just got a fine line paint pen from Michaels but haven't had a chance to use it yet. Scribes, wires & nails are great but yes they're harder to see.
