Post by miket on Feb 27, 2020 19:59:38 GMT -5
Concrete. I opened my vibe after 2 days in 120/220 and that's what I have. Too much water, not enough water, something else?
Post by knave on Feb 27, 2020 20:08:16 GMT -5
After a certain point there’s just too much gunk in that first stage. Only fix is a cleanout imo. Usually means the grit is gone anyway.
Post by miket on Feb 27, 2020 20:17:31 GMT -5
After a certain point there’s just too much gunk in that first stage. Only fix is a cleanout imo. Usually means the grit is gone anyway. So weird. Thanks, it's only my second time using it and of course the first time went without a hitch.
EricD
High in the Mountains
Member since November 2019
Post by EricD on Feb 27, 2020 20:33:21 GMT -5
What vibe are we talking about here?
Post by miket on Feb 27, 2020 20:53:06 GMT -5
What vibe are we talking about here? tv- 5
Post by knave on Feb 27, 2020 20:56:45 GMT -5
Concrete. I opened my vibe after 2 days I think Mike is rocking the TV-5. The vibe tumblers work so much faster. Especially on 120 SiC, the rock dust can absorb all the free water and make concrete. I believe it was Drummond Island Rocks who said he likes to start that stage early in the morning so he can check on it after a couple of hours and add water. Looks can be deceiving. I like to pick up some material in my fingers as it runs. If it is “sticky” where the ceramic sticks to 1 spot on the rock, it needs more water. Perfect is a nice film of grit on all the rocks, too wet and the grit would wash off in the bottom. 120 requires at least 2x day checkups. I had a Lot-O load that the small ceramics and small rocks had turned into a mass of concrete at the bottom, From the top every thing looked ok, action was a bit slow, but the big rocks were just staying at the top. Hopefully this helps a bit.
EricD
Post by EricD on Feb 27, 2020 21:03:52 GMT -5
What knave said. you must check your vibe all the time. haha
Post by miket on Feb 27, 2020 21:04:20 GMT -5
Concrete. I opened my vibe after 2 days I think Mike is rocking the TV-5. The vibe tumblers work so much faster. Especially on 120 SiC, the rock dust can absorb all the free water and make concrete. I believe it was Drummond Island Rocks who said he likes to start that stage early in the morning so he can check on it after a couple of hours and add water. Looks can be deceiving. I like to pick up some material in my fingers as it runs. If it is “sticky” where the ceramic sticks to 1 spot on the rock, it needs more water. Perfect is a nice film of grit on all the rocks, too wet and the grit would wash off in the bottom. 120 requires at least 2x day checkups. I had a Lot-O load that the small ceramics and small rocks had turned into a mass of concrete at the bottom, From the top every thing looked ok, action was a bit slow, but the big rocks were just staying at the top. Hopefully this helps a bit. That's exactly how mine was. Looked good on top, a mass on the bottom. Guess I'll have to pay better attention. Thanks Evan.
Post by victor1941 on Feb 27, 2020 22:04:50 GMT -5
I use a Thumbler UV-18 and have found that in the first stage the tumble should be checked at least every two hours. The later stages with less grinding don't need such frequent monitoring and the polish stage hardly needs any extra water.
Post by miket on Feb 27, 2020 22:21:15 GMT -5
I use a Thumbler UV-18 and have found that in the first stage the tumble should be checked at least every two hours. The later stages with less grinding don't need such frequent monitoring and the polish stage hardly needs any extra water. Thanks!
Trylobyte
Member since October 2003
Post by Trylobyte on Mar 28, 2020 13:08:17 GMT -5
I also have a couple UV-18s, and have put hundreds of pounds of agate through them. Super important to check them frequently, like every few hours, until you have them dialed in and your experience level can guide you. If the rocks stop turning over, then you'll simply grind a hole in the bottom of the tub, and squander some coin. Basically, I look at the bottom of the donut while the rocks are turning over, and make sure there's "a little" standing liquid. Very little, but some. Too much water, the action stops or you're just washing the grit off...too little and the action stops. And use some borax. I put 1/2 cup in my vibes. The borax will take an hour or so to dissolve, so check it and add water as required to get a good grinding action...just a little water...a tablespoon at a time.
ataraktos
Member since January 2020
Post by ataraktos on Mar 30, 2020 18:27:04 GMT -5
What knave said. you must check your vibe all the time. haha Seriously true. I'm just getting going with the lot-o. Wish I'd've set the thing up in the bathroom!
Post by mohs on Mar 30, 2020 18:41:44 GMT -5
people who vibe & tumble in the bedroom is social togatherness at its best mostly I know my room as everything
mirdonamy
Don't step on the momeraths!
Member since March 2020
Post by mirdonamy on Mar 30, 2020 18:41:58 GMT -5
Great info here! So, where do you get Borax nowadays? I don't even know what it looks like on a shelf, but my local store (Wal-Mart) has empty shelves in the cleaning supplies aisles.
Post by knave on Mar 30, 2020 18:45:18 GMT -5
people who vibe & tumble in the bedroom is social togatherness at its best mostly I know my room as everything Which one of several meaning here? Hmmm It is togetherness at its best for sure.
Post by mohs on Mar 30, 2020 18:55:02 GMT -5
remember to practice safe vibe & tumbling your rocks will appreciate it mohs
Post by knave on Mar 30, 2020 18:58:33 GMT -5
Post by joshuamcduffie on Mar 30, 2020 18:58:59 GMT -5
Great info here! So, where do you get Borax nowadays? I don't even know what it looks like on a shelf, but my local store (Wal-Mart) has empty shelves in the cleaning supplies aisles. It comes in a box like powdered detergent, and is probably near the laundry detergent as well. Most non rock tumblers use it as a detergent booster.
Post by knave on Mar 30, 2020 18:59:31 GMT -5
20 Mule Team is one brand
mirdonamy
Post by mirdonamy on Mar 30, 2020 19:27:22 GMT -5
20 Mule Team is one brand Is $22 a good price for 65 oz?
