Post by opalpyrexia on Mar 15, 2020 16:12:49 GMT -5
A while back I purchased a Laguna slab and was immediately drawn to a notch loaded with crystals. After cutting it, I let it sit for a couple of weeks before coming up with a pendant design. And then ................
While soldering up the silver, I placed the pendant in a plastic bag on my woodworking bench. At some point it slid off the messy bench and onto the concrete floor. I examined it in the bag and it looked just fine, so I finished soldering for the day. The next day, when it came time to set the agate, I removed it from the bag and discovered this heartache —
"Aw, <expletive>!"
After I calming down over an hour, I reluctantly resorted to 330 epoxy and then, of course, there was no turning back. The agate is paired with a 5mm rubellite tourmaline on the "halo" above:
There wasn't supposed to be any texturing on the tourmaline's halo, but an extremely tiny piece of solder managed to find its way up there and leave a little bump. I think that the sparkle of the texture seems to "flow from" the druzy crystals. There was also a little firestain that would have been very difficult to remove. Hiding is so much easier.
To add to my headache, the tourmaline had a little rattle — something I've never had happen. So I really hammered hard on it to set it tight, even to the point of bending the halo silver ...... but no luck. After straightening the halo ("Thanks, parallel pliers!") I used a trick to tighten the setting. Using a fine point knife graver, I raised a couple of stitches of silver from inside the back of the tube setting to press up onto the back of the stone. Success!
Dual hidden bails have become my go-to method for many pendants —
Post by fernwood on Mar 15, 2020 16:18:24 GMT -5
What a beautiful adaptation. I love it. Cannot see any indication that it was glued together. I also love the sparkle effect on the halo.
I nominate this piece for the "recovery" of the year.
Post by Pat on Mar 15, 2020 16:25:56 GMT -5
Excellent class in recovery!! Beautiful piece! Thanks.
Post by rockjunquie on Mar 15, 2020 16:31:15 GMT -5
Before I read that the halo glitter was a boo boo, I was like- Great idea and excellent job. Looks perfect. Persistence paid off in a beautiful piece. I love it.
Post by hummingbirdstones on Mar 15, 2020 16:33:21 GMT -5
Despite all of the challenges you had on this piece, it came out marvelous!
Thanks for all the pictures and describing your processes. I really like the textured top. I've resorted to that trick a few times myself.
Post by beefjello on Mar 15, 2020 17:08:22 GMT -5
Nice save on the fracture, and wow what a magnificent piece all around!!
Post by opalpyrexia on Mar 15, 2020 17:19:42 GMT -5
Thank you all for your nice comments!
Post by opalpyrexia on Mar 15, 2020 17:21:33 GMT -5
Thanks, I like the way it turned out, too.
jasperfanatic
Post by jasperfanatic on Mar 15, 2020 17:39:09 GMT -5
If I believed in that sort of thing, I'd say it was all meant to be in order for it to turn out so fantastic! Great job!
Post by mohs on Mar 15, 2020 18:32:13 GMT -5
right on Pal!
the poxy fix seamless and beatiful know that heartache often ha
a duzy of a fine pendant !
Post by MsAli on Mar 15, 2020 18:52:52 GMT -5
You probably couldn't of done a better job if you were trying to do all of that on purpose
And as Kevin pointed out it turned out exactly how it was meant to -(like everything does)
Post by toiv0 on Mar 15, 2020 19:27:51 GMT -5
Whew, AMEN!
Post by knave on Mar 15, 2020 19:56:54 GMT -5
You tell em Brother Billy
Wonderful piece!
Post by RocksInNJ on Mar 15, 2020 22:52:27 GMT -5
Glad it all worked out for you. You did a fine job.
gemfeller
Member since June 2011
Member is Online
Post by gemfeller on Mar 16, 2020 0:10:19 GMT -5
A very classy result. I like the texturing, which I think adds a desirable complexity to the piece. Nice work.
mgrets
Member since February 2011
Post by mgrets on Mar 18, 2020 11:01:59 GMT -5
Beautiful save! The tourmaline really finishes it off nicely.
Post by Drummond Island Rocks on Mar 18, 2020 17:12:51 GMT -5
Turned out beautiful. Nice design and execution.
Post by lpl on Mar 19, 2020 11:52:02 GMT -5
That is a beautiful piece!
Post by miket on Mar 19, 2020 12:38:50 GMT -5
I missed this post, glad it got a bump. That one is spectacular, love it!
raqy
Member since March 2007
Post by raqy on Apr 20, 2020 23:19:11 GMT -5
Everything happens for a reason... this piece is exquisite.
