pstablee
Member since March 2020
Post by pstablee on Mar 21, 2020 19:15:34 GMT -5
Hi there!
Thanks for reading, I’m a newbie, I got a tumbler for Christmas this year and have just started using it. I have a potentially stupid question... does the 3lb capacity mean I can put up to 3lbs or rocks in the barrel or does that indicate the capacity of the motor including the weight of the barrel itself? To be safe I’ve only been putting up to 1lb of rocks so far.
Thank you!!
-Paige
Post by knave on Mar 21, 2020 19:33:28 GMT -5
Fill the barrel 2/3 or 3/4 full with rock, add grit, and water to bottom of the top rock layer. It will weigh far more than 3 lbs at that point but no matter. You got extra belts with your tumbler, all is fine.
Welcome to RTH!
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Mar 22, 2020 8:16:24 GMT -5
The 3 Pound designation indicates the barrel size, it does not indicate how much to put in there.
