Post by holajonathan on Apr 19, 2020 13:34:38 GMT -5
Post by fernwood on Apr 19, 2020 13:37:33 GMT -5
No photo appeared.
Post by holajonathan on Apr 19, 2020 13:40:40 GMT -5
Post by fernwood on Apr 19, 2020 13:42:16 GMT -5
Love your cat. Do you know if the rock is metallic? How hard is it?
Post by holajonathan on Apr 19, 2020 13:44:04 GMT -5
Love your cat. Do you know if the rock is metallic? How hard is it? I don't know how to tell if it is metallic. Any advice? It is very hard and dense. Agate-like hard. Looks and feels like a Lake Superior agate, but the color / luster is not like any agate I have seen.
jasperfanatic
Post by jasperfanatic on Apr 19, 2020 13:57:18 GMT -5
Maybe some worn pyrite or chalcopyrite? Not sure what you want to do with it (nor not do with it), but I can think of a number of things to try that may or may not have scientific significance ...like chipping a piece off, or throwing it in the saw, or put a drop of acid on it and look for a reaction, seeing if it's magnetic, or even a scratch test to try and determine hardness. I'm sure there are knowledgeable folks here that can help that won't take my uneducated "scorched earth" approach to mineral identification. I'm looking forward to seeing what everyone has to say about it, I'm as curious as your cat seemed to be (if only for a moment or two).
Post by Deleted on Apr 19, 2020 14:34:07 GMT -5
I'll also throw in my hat as suspecting pyrite (in which case, it is going to be weakly or non-magnetic). Looks very much like some of the pyrite concretions I've found in the past. If you are going to cut it, sulfides give off a sulfur (egg) smell. Second the 'like' on the cute, rock-loving kitty!
Post by mohs on Apr 19, 2020 14:50:58 GMT -5
obviously its pet. catnip
good photo's !
Post by pauls on Apr 19, 2020 17:06:58 GMT -5
It looks like Pyrite.
agatemaggot
Member since August 2006
Post by agatemaggot on Apr 19, 2020 18:06:18 GMT -5
Cool looking rock , and, cat wife has 2 rock cats, will pick up and run off with anything small enough to make off with.
Ya gotta watch em !
rptorman
Member since April 2020
Post by rptorman on Apr 19, 2020 20:11:44 GMT -5
Might try a metal detector to see if it's metallic.
Post by MsAli on Apr 19, 2020 20:28:13 GMT -5
Not even gonna give an uneducated guess but the cat is awesome
fuss
Post by fuss on Apr 20, 2020 8:43:25 GMT -5
A couple easy DIY tests you could do to help with the ID.
A streak test, take your toilet lid off and flip it over, scrape the rock against the rough porcelain material and note the color of the mark left if any. Pyrite will leave a dark greenish black streak.
Second, try scratching the rock with a pushpin or knife blade, if a scratch mark is left it is not quartz (agate is quartz) and is likely not pyrite unless the surface area is softer from weathering. If no scratch mark is left try scratching it with a piece of known quartz and note the result.
Like noted above, chipping off a piece and posting a close up photo would be very helpful.
Post by knave on Apr 20, 2020 9:56:12 GMT -5
Wow, pic 4 has everything in focus!
Post by holajonathan on Jul 31, 2021 1:47:15 GMT -5
Post by holajonathan on Jul 31, 2021 1:57:22 GMT -5
Hats off to jasperfanatic pauls and fuss for getting it right. I wanted it to be a meteorite. It turns out to be a meteorwrong.
Post by fernwood on Jul 31, 2021 3:48:35 GMT -5
Thanks for the update.
Post by perkins17 on Jul 31, 2021 8:55:12 GMT -5
Hats off to jasperfanatic pauls and fuss for getting it right. I wanted it to be a meteorite. It turns out to be a meteorwrong. I thought/ hoped it was a meteorite as well. To bad. Nice rock though!
Post by greig on Aug 1, 2021 8:20:01 GMT -5
I spotted a similar one in a historic BC gold creek. I was hoping for gold, but no such luck. I got completely soaked in freezing water trying to retrieve it. Good from far and far from good. Then I also wondered about meteorite, because it kinda looked molten, but was not magnetic and my metal detector didn't detect it. I put it on a shelf for a number of years and it got dull and brown. Now that I know more, it is a pyrite nodule.
agatemaggot
Post by agatemaggot on Aug 1, 2021 8:33:31 GMT -5
Great looking Cat, and the rock isn't bad either !
