saxplayer
Member since March 2018
Post by saxplayer on May 12, 2020 20:35:15 GMT -5
My 12lb lortone motor keeps stopping. I’ll go check on the tumbler and it’s not moving at all. I unplugged it and waited an hour and it stopped again 7 hours later. I dismantled the motor and it seems to spin fine without binding.
Thoughts? Over heating and then self cooling by shutting off?
I have 2 qt-12 neither have done this before. My belt is not slipping and tension seems fine. Barrels are full but nothing I don’t normally do.
Post by rmf on May 13, 2020 6:28:59 GMT -5
How old is it? It may just be a bad motor. When you turn it on after being unplugged does it have any torque?
Post by knave on May 13, 2020 8:47:15 GMT -5
Is the motor very hot? Are the bushings gummed up?
Post by miket on May 13, 2020 9:20:20 GMT -5
I was having the same issue with my 33b. Cleaned it, put on a new belt, replaced the bearings, did everything I could think of. It would run fine with no barrels or one barrel but not both. I finally got a motor off of ebay for $33 and it's been running ever since.
Post by Fossilman on May 13, 2020 10:57:50 GMT -5
Sounds like motor is toasted... Easy to replace...
saxplayer
Post by saxplayer on May 13, 2020 11:12:46 GMT -5
Sounds like motor is toasted... Easy to replace... Can’t find a motor easily right now. They seem to be out of stock lol
Post by miket on May 13, 2020 11:42:48 GMT -5
saxplayer
Post by saxplayer on May 13, 2020 15:38:56 GMT -5
Thanks for the link. I called them and they are out. Likely will have to wait until Lortone is back open.
Post by miket on May 13, 2020 16:40:07 GMT -5
Thanks for the link. I called them and they are out. Likely will have to wait until Lortone is back open. Dang, sorry about that. The website lied.
Post by aDave on May 13, 2020 19:47:00 GMT -5
Grant saxplayer, you may want to try Minnesota Lapidary Supply. The motor is listed in their catalog for an okay price ($20 more than Rock Shed), so maybe you'll luck out with them having it in stock. I looked at Kingsley North, and they are out of stock. Rocktumbler.com looks like they might have it (I could add it to the cart), but their price is pretty darn expensive. Just depends how badly you need it.
saxplayer
Post by saxplayer on May 13, 2020 21:01:50 GMT -5
Grant saxplayer, you may want to try Minnesota Lapidary Supply. The motor is listed in their catalog for an okay price ($20 more than Rock Shed), so maybe you'll luck out with them having it in stock. I looked at Kingsley North, and they are out of stock. Rocktumbler.com looks like they might have it (I could add it to the cart), but their price is pretty darn expensive. Just depends how badly you need it. Thanks man. I did call TRS and it sounds like they may have something brewing soon.
salpal48
Member since March 2015
Post by salpal48 on May 17, 2020 14:14:02 GMT -5
Before you dump the Motor. Remove from the machine submerge the entire Motor In Oderless mineral spirits overnight. In the am shake out and let dry for a Few Hours. Plug in. the mineral spirits Dissolve any gum and oil . . Do not Plug in while in the solution
Post by aDave on May 18, 2020 16:04:57 GMT -5
Before you dump the Motor. Remove from the machine submerge the entire Motor In Oderless mineral spirits overnight. In the am shake out and let dry for a Few Hours. Plug in. the mineral spirits Dissolve any gum and oil . . Do not Plug in while in the solution Don't mean to hijack a bit, but it's still QT related. I recall your discussion about copper bushings that you got for your QT tumbler(s), but I was a bit confused at the end of the day as to what you used. Do you have a specific item that you can point to? I seem to recall you found something that was a direct replacement for the plastic ones. Thanks.
saxplayer
Post by saxplayer on May 18, 2020 16:44:52 GMT -5
Hmm.. I oiled up the motor at the 2 oil points... cleaned up whatever gunk I could see physically and it's run for 3 days now without issue. here's to hoping it's not bad down the road. Next time I will probably try the mineral spirits thing once and see what happens I'll get a new motor eventually I suspect.
salpal48
Post by salpal48 on May 18, 2020 17:54:25 GMT -5
Before you dump the Motor. Remove from the machine submerge the entire Motor In Oderless mineral spirits overnight. In the am shake out and let dry for a Few Hours. Plug in. the mineral spirits Dissolve any gum and oil . . Do not Plug in while in the solution Don't mean to hijack a bit, but it's still QT related. I recall your discussion about copper bushings that you got for your QT tumbler(s), but I was a bit confused at the end of the day as to what you used. Do you have a specific item that you can point to? I seem to recall you found something that was a direct replacement for the plastic ones. Thanks. If you go to asbbearingsonline.com. Go to flange bushing , you will see list of sized. what lortone do you have and how old. the model # QT6 or QT12 will not help. The shaft size is the same 1/2 " but Lortone has cut the Hole in the base different from time to time. If you PM me we can discuss or open another Thread
Post by aDave on May 18, 2020 19:14:45 GMT -5
Don't mean to hijack a bit, but it's still QT related. I recall your discussion about copper bushings that you got for your QT tumbler(s), but I was a bit confused at the end of the day as to what you used. Do you have a specific item that you can point to? I seem to recall you found something that was a direct replacement for the plastic ones. Thanks. If you go to asbbearingsonline.com. Go to flange bushing , you will see list of sized. what lortone do you have and how old. the model # QT6 or QT12 will not help. The shaft size is the same 1/2 " but Lortone has cut the Hole in the base different from time to time. If you PM me we can discuss or open another Thread Thanks. I will send you a PM.
saxplayer
Post by saxplayer on May 18, 2020 19:41:58 GMT -5
If you go to asbbearingsonline.com. Go to flange bushing , you will see list of sized. what lortone do you have and how old. the model # QT6 or QT12 will not help. The shaft size is the same 1/2 " but Lortone has cut the Hole in the base different from time to time. If you PM me we can discuss or open another Thread Thanks. I will send you a PM. I’m kinda interested now too lol.
Post by aDave on May 18, 2020 20:17:47 GMT -5
Thanks. I will send you a PM. I’m kinda interested now too lol. I figured I wouldn't be the only one. If he replies to my PM, I'll see if he'll just add the info to this thread. Heck, it certainly relates to working on the tumbler and making sure it's turning optimally.
dkurtz
Tumbling to de-stress from my work. :)
Post by dkurtz on Jun 18, 2020 16:25:45 GMT -5
Before you dump the Motor. Remove from the machine submerge the entire Motor In Oderless mineral spirits overnight. In the am shake out and let dry for a Few Hours. Plug in. the mineral spirits Dissolve any gum and oil . . Do not Plug in while in the solution Thank you so much. The mineral spirits revived one of my motors, now soaking another. The 2nd stopped a couple weeks ago for me so I tried it again and it works but I'm soaking overnight anyway to clean it. I guess I'll try it also on a few other motors I have sitting around. Glad I didn't throw them out. Thanks again David
salpal48
Post by salpal48 on Jun 19, 2020 15:27:54 GMT -5
Yes, The Mineral Spirits work . it is not a Fix all. remember a motor sucks in all the dust , dirt and whatever else. all of it sticks and over oiling will harden and cause it to be sluggish. This was a trick my father taught me Thanks Sal
