Post by glennz01 on May 18, 2020 1:15:13 GMT -5
Post by Fossilman on May 18, 2020 10:25:43 GMT -5
Yuppers, those should do the job....
Post by RWA3006 on May 18, 2020 18:27:51 GMT -5
glennz01 Tell us what kind of grinder you are using them on. Hand held? Stationary? I want to know more. Thanks
Post by glennz01 on May 21, 2020 9:36:43 GMT -5
glennz01 Tell us what kind of grinder you are using them on. Hand held? Stationary? I want to know more. Thanks Water fed angle grinder, Amazon special.
Post by HankRocks on May 21, 2020 9:49:45 GMT -5
glennz01 Tell us what kind of grinder you are using them on. Hand held? Stationary? I want to know more. Thanks Water fed angle grinder, Amazon special. How do you plan on holding the slabs in place. Without some way of fixing them in place the grinder will launch them.
Post by glennz01 on May 21, 2020 15:36:49 GMT -5
Water fed angle grinder, Amazon special. How do you plan on holding the slabs in place. Without some way of fixing them in place the grinder will launch them. I put the slab on a block of wood, the friction pressure keeps it in place. My grinder is variable speed to about 6000 from do it's not too fast to do that.
