oldschoolrocker
Post by oldschoolrocker on Jul 27, 2020 9:11:12 GMT -5
so I started cutting into some Holt Canyon agate that I purchased and it is literally crumbling to pieces before I can get a slab cut. I've read that Holt canyon material generally contains a lot of fractures but was hoping the hard part was working around fractures in a slab, not just cutting a slab. the material is gorgeous and I'd hate to see it go to waste so am wondering if there is a stabilization method I could use on it that would allow me to cut a slab without it falling apart during cutting. or with how fractured the material is would I be wasting my time? here it is wet and dry.. thanks in advance for the help!
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Jul 27, 2020 12:28:28 GMT -5
Hate when that happens.
zarguy
Member since December 2005
Post by zarguy on Jul 27, 2020 12:35:00 GMT -5
I love Holt Canyon agate/jasper, but it is hard to find pieces that are fracture-free. I'm very selective on what I bring home and even then have to stabilize many chunks, slabs, preforms & cabs. In other words - I stabilize it at all stages if necessary.
Hxtal is my epoxy of choice. It's relatively expensive and has a long cure time (heat speeds that up), but it's worth it. Good luck with the material you bought. Lynn
Post by 1dave on Feb 6, 2021 13:53:14 GMT -5
I love Holt Canyon agate/jasper, but it is hard to find pieces that are fracture-free. I'm very selective on what I bring home and even then have to stabilize many chunks, slabs, preforms & cabs. In other words - I stabilize it at all stages if necessary. Hxtal is my epoxy of choice. It's relatively expensive and has a long cure time (heat speeds that up), but it's worth it. Good luck with the material you bought. Lynn www.hxtal.com/
Post by Fossilman on Feb 8, 2021 11:24:39 GMT -5
Hopefully you can get a few cabs off it to break even with the material....
Post by roy on Feb 8, 2021 13:42:44 GMT -5
send it to me ill stabilize it for you and send back
oldschoolrocker
Post by oldschoolrocker on Feb 8, 2021 15:08:32 GMT -5
send it to me ill stabilize it for you and send back I'd be happy to do that! can you PM me an address to send it to?
