Post by mohs on Oct 5, 2020 16:02:05 GMT -5
it was significant amount of water that leaked but can't find any obvious wet spot does anyone have any techy ideas how to locate a plumbing water leak? Thanks Ed
Post by parfive on Oct 5, 2020 16:34:56 GMT -5
What do you suspect, Ed?
hot water line cold water line drain
intermittent leak or steady
what kind of pipe any galvanized
Post by mohs on Oct 5, 2020 16:47:53 GMT -5
good question Rich
main water line most likely 70 year old corroded pipe for sure
We were notified by SRP a week ago that we had significant leak Indeed it was
the bill was 350 bucks Where its normally 50
Tom figures that it was leaking a gallon an hour.
So now the leak as slowed considerably
I just checked the meter
its reading: 81738 earlier at 10 am the meter read: 81728 4 hour difference
not sure if any water was used I just got back so Tom might have used water
but the leak is steadily slower yet constant it seems….
Thanks!
Post by knave on Oct 5, 2020 16:50:32 GMT -5
Water meter electronic or mechanical?
Post by knave on Oct 5, 2020 16:51:17 GMT -5
Are the toilets all quiet
Post by mohs on Oct 5, 2020 16:58:59 GMT -5
the stool is solid... m stly I think the meter is electronic see an electrical connection gizmo on that its the pipe most likely that goes under that concrete slab but there is another another apartment house out back that as branching water pipe to it this old house is tricked out I just try to grind rocks here mostly but i am vested in thanks guys ~ maybe can learn something
Post by parfive on Oct 5, 2020 17:12:40 GMT -5
Something’s rotten in Denmark, Ed . . . or Phoenix.
A gallon an hour would be 720 gallons a month. On my water bill, that would cost me $4.23.
Actual rate is $4.234 per hundred cubic feet, which is 748 gallons.
Post by knave on Oct 5, 2020 17:17:41 GMT -5
Isolate sections as much as you can. Like the section under ground. If meter spins when that section is pressured it’s bad, run pex above ground somewhere. If meter keeps spinning when valves off, the meter is bad. Any suspicious green grass around?
Post by parfive on Oct 5, 2020 17:20:01 GMT -5
I’d have to leak over 53,000 gallons in a month, Ed, to bump my water bill three hundred bucks.
That’s about 74 gallons an hour!
Like I said . . . Denmark.
Post by knave on Oct 5, 2020 17:26:07 GMT -5
A large leak won’t fix itself. Meter not spinning now? Really weird.
Post by mohs on Oct 5, 2020 17:29:46 GMT -5
A large leak won’t fix itself. Meter not spinning now? Really weird. exactly things like this only get worse Tom will figure it out he dug one heck of hole hopefully he doesn't bury me in it never knohs
Post by mohs on Oct 5, 2020 17:33:15 GMT -5
interesting Rich I obviously misheard Tom's usage estimate I don't think APS is pulling a fast one but it possible this is strangest place I ever known you have NO idea
Post by knave on Oct 5, 2020 17:34:41 GMT -5
Post by mohs on Oct 5, 2020 17:36:49 GMT -5
Yeah Rich the bill was that high and if it was leaking that sort of galleons you quoted then a flooded spot seems like it would be obvious
anyway I'm going to keep a watch on that meter the alley a little dangerous so I'll bring the Great Dane w/me
Post by amygdule on Oct 5, 2020 18:02:05 GMT -5
Any Green spots in your landscape ? Weeds growing where they shouldn't be.
Post by mohs on Oct 5, 2020 18:05:07 GMT -5
lot of illegal things growing around here but nothing out the un-ordinary
Post by mohs on Oct 5, 2020 18:09:02 GMT -5
the whole yard looks like that hole except for mohs rocks and few other scattered items o heck this place as everything c/mon I'll show you
JBe
Post by JBe on Oct 5, 2020 18:35:10 GMT -5
If you're sure the leak is somewhere between the meter and the house it may be more cost effective to just run a new connection and abandon the old. It depends on the distance and how much of it is under concrete or other obstructions. The entire run is most likely the same age so if one spot aged to the point of leaking you may spend a bunch of resources isolating and patching it only to have another spot start leaking six months from now.
Something to consider.
Post by mohs on Oct 5, 2020 18:38:04 GMT -5
If you're sure the leak is somewhere between the meter and the house it may be more cost effective to just run a new connection and abandon the old. It depends on the distance and how much of it is under concrete or other obstructions. The entire run is most likely the same age so if one spot aged to the point of leaking you may spend a bunch of resources isolating and patching it only to have another spot start leaking six months from now. Something to consider. The plumbing line from the meter to the hole in the back yard had already been previously replaced. Its still possible the leak exist there-- but less likely, Anyway just wanted to remark JBe I really appreciate your commenting Ed just checked the meter @ 4 p.m 81743 2 hours previously @ 2 p.m 81738 net cubic feet usage = 00005 I think that fairly reasonable for this old house sort of any ideas?
Post by knave on Oct 5, 2020 18:46:49 GMT -5
That’s 40 gallon in 2 hours. Where did it go
