labdoc
Member since October 2020
Post by labdoc on Oct 19, 2020 13:50:49 GMT -5
I'm an old hand at tumbling but new to cabbing. From research I've done here, got myself a Hi-Tech 10" slant cabber to start. Works well and grinding down rocks has become addictive. Already shaped a few practice rocks and they look OK. I ordered some new disks and they are aluminum plate. The ones that came with the cabber, stick on an acrylic backing plate. Do I need to back up the aluminum? They seem pretty sturdy to me and I'd think could stand up on their own, ?
Post by rockjunquie on Oct 19, 2020 14:26:53 GMT -5
I'm an old hand at tumbling but new to cabbing. From research I've done here, got myself a Hi-Tech 10" slant cabber to start. Works well and grinding down rocks has become addictive. Already shaped a few practice rocks and they look OK. I ordered some new disks and they are aluminum plate. The ones that came with the cabber, stick on an acrylic backing plate. Do I need to back up the aluminum? They seem pretty sturdy to me and I'd think could stand up on their own, ? Welcome from Virginia.
That's probably a good question to ask the manufacturer. I'm not sure, but those metal backers may be too heavy for your motor. My flat lap has acrylic backers. (different brand)
Post by jasoninsd on Oct 19, 2020 19:46:03 GMT -5
I don't have an answer for your question, but welcome to the forum from South Dakota.
labdoc
Post by labdoc on Oct 20, 2020 5:32:31 GMT -5
The plates weigh about the same and being the inpatient person I am, tried it. The only problem was the plate is thinner than the acrylic, so I need a shorter screw to clamp it down. Once I figured that out everything went smoothly, seems to work just fine, I guess until it doesn't. But for now, I'm good.
Post by hummingbirdstones on Oct 20, 2020 8:50:46 GMT -5
I use a master lap under the metal toppers on my flat lap. It heavy and doesn't bog down the motor at all. I have an old Hi-Tech - not a slant lap.
Just adding a an extra washer or two between the lap and the nut works, too.
Post by opalpyrexia on Oct 20, 2020 10:15:17 GMT -5
Welcome from Washington.
Post by stephan on Oct 20, 2020 21:47:06 GMT -5
Welcome from NorCal
Post by Fossilman on Oct 22, 2020 9:52:29 GMT -5
Howdy and welcome...
Post by TheRock on Mar 15, 2021 22:41:07 GMT -5
Welcome to RTH Forum from S/W Michigan! ~Duke
