Post by Pat on Nov 10, 2020 15:34:36 GMT -5
Sometimes a Genie wheel gets used and used till it no longer works, then what? Seems like they ought to be good for something. What do you do with your worn out wheels? Thank you, rockpickerforever
gemfeller
Member since June 2011
Post by gemfeller on Nov 10, 2020 16:16:26 GMT -5
Pat, I send mine to Johnson Bros. for recoating. It doesn't matter what grit they were originally - just specify the new grits you want. I've been using their recoated wheels with good results for over a year now.
Post by rockjunquie on Nov 10, 2020 20:24:29 GMT -5
I bought an extra arbor and put my really, really worn 80, 220 and 220 (soft) on it for working some softer and temperamental stones (like jade).
gemfeller, I need to do that, but just can't bite the bullet. I need a 1200 and 3000. Have you had those grits done and were they ok- no larger grit contamination?
gemfeller
Post by gemfeller on Nov 11, 2020 1:06:00 GMT -5
gemfeller, I need to do that, but just can't bite the bullet. I need a 1200 and 3000. Have you had those grits done and were they ok- no larger grit contamination? Yes, I've done those grits and they're fine. Their process makes the wheels harder and less "springy" than Novas but I don't mind that the way I cut. It might make a difference for some people.
Post by rmf on Nov 11, 2020 6:03:44 GMT -5
gemfeller , I need to do that, but just can't bite the bullet. I need a 1200 and 3000. Have you had those grits done and were they ok- no larger grit contamination? Yes, I've done those grits and they're fine. Their process makes the wheels harder and less "springy" than Novas but I don't mind that the way I cut. It might make a difference for some people. What does it cost for a 6" wheel to be re-coated with diamond?
Post by rockjunquie on Nov 11, 2020 7:44:28 GMT -5
gemfeller , I need to do that, but just can't bite the bullet. I need a 1200 and 3000. Have you had those grits done and were they ok- no larger grit contamination? Yes, I've done those grits and they're fine. Their process makes the wheels harder and less "springy" than Novas but I don't mind that the way I cut. It might make a difference for some people. I bought a "soft" wheel from the Baltic company. It didn't have much give, which wasn't so bad, really, but it was insanely loud. Are the Johnson wheels loud? I can't do that again.
gemfeller
Post by gemfeller on Nov 11, 2020 10:06:04 GMT -5
rockjunquie - "I bought a "soft" wheel from the Baltic company. It didn't have much give, which wasn't so bad, really, but it was insanely loud. Are the Johnson wheels loud? I can't do that again." They're very similar to regular Nova wheels. Not especially loud in my experience. I did buy one of their new (not recoated) 8K wheels and it's a little stiffer and louder than others I've used but not too bad. But it's hard to gauge other people's reaction.
gemfeller
Post by gemfeller on Nov 11, 2020 10:12:51 GMT -5
Yes, I've done those grits and they're fine. Their process makes the wheels harder and less "springy" than Novas but I don't mind that the way I cut. It might make a difference for some people. What does it cost for a 6" wheel to be re-coated with diamond? Their current price is $24.95 per 6" wheel plus postage. You have to send them your old wheels. www.johnsonbrotherslapidary.com/ReSurfacing_Diamond_Wheels.html
Post by rockjunquie on Nov 11, 2020 12:13:19 GMT -5
rockjunquie - "I bought a "soft" wheel from the Baltic company. It didn't have much give, which wasn't so bad, really, but it was insanely loud. Are the Johnson wheels loud? I can't do that again." They're very similar to regular Nova wheels. Not especially loud in my experience. I did buy one of their new (not recoated) 8K wheels and it's a little stiffer and louder than others I've used but not too bad. But it's hard to gauge other people's reaction. Thank you. Yes, I suppose it is a bit subjective, but if the JB wheel were as loud, you would know what I was talking about. It's very loud and more high pitched. Drove me nuts. I basically tossed it.
Post by stardiamond on Nov 11, 2020 17:50:54 GMT -5
For the years I cabbed and had a job, speed was important because I had limited free time. When a wheel was still usable but not near max efficiency, I replaced it. It is easy to sell usable wheels to those who are starting out and on a budget. I do a lot of heavy lifting with my 80 grit and when the cutting slows only a little, I consider replacement. I'm impatient and like to watch the rock dissolve as long as it doesn't chip.
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Nov 11, 2020 18:41:20 GMT -5
Might have to try this out
Post by rmf on Nov 12, 2020 4:00:06 GMT -5
gemfeller Thanks for the info and link. I have a couple of worn wheels to try.
Post by Mel on Nov 23, 2020 17:40:58 GMT -5
D'oh. Just realized this is for soft wheels. Was hoping to find my elusive "affordable" hard wheel replacement. Guess I gotta keep looking!
