Post by oregon on Dec 10, 2020 16:03:03 GMT -5
These flex shafts were in with a bunch of lapidary equipment, most of which was "vintage". The steel one looks unused, in an ancient plastic sack, factory pipecleaners intact (era before zip ties) They seem to both have 1/4" shafts, and the normal dremel type collets on the other end. But there also doesn't seem to be any real way of anchoring the outer casing? Did old Foredom units use this type of connection, or is a connector of some sort missing for those machines? Strange mounting assembly for the used shaft...
Trying to figure out what they are before I figure out what to do with them. Thanks.
Post by Pat on Dec 10, 2020 16:25:41 GMT -5
Bottom one looks familiar. I have some old Foredoms.
Post by quartz on Dec 11, 2020 0:27:37 GMT -5
What do you think of this as a solution to your question? McMaster-Carr 1932
Post by oregon on Dec 11, 2020 18:48:55 GMT -5
I guess flex shafts have been around for a while...
