QuailRiver
Post by QuailRiver on Dec 18, 2020 21:52:12 GMT -5
This item is now SOLD. Thank you. This is a used steel Tumbling Barrel with a rubber liner. I believe that it is considered a 6 lb barrel. It's outside diameter measures 9-3/8" and it is 5" wide when including the length of the bolts and wing nuts. I bought this barrel and some other lapidary equipment from a local estate liquidator last winter. I don't have a working tumbler base for these larger diameter barrels so don't need it. Judging from the condition of the barrel liner it does not appear to have had a lot of use from the previous owner. The reddish/brown color around the edges of the rubber appears to be red rouge pre-polish residue. The price is $35.00 plus $18.70 shipping in a USPS large flat rate priority box anywhere in the U.S.. If you would like to purchase this tumbler barrel then private message me your email address and I will send you a Pay Pal invoice. Larry C.
