claire
Member since January 2021
Post by claire on Jan 26, 2021 8:49:23 GMT -5
Hello! I’m new to this forum. But I’ve been reading lots of posts here about the Genie geysers and how they often stop working. The Art center where I take classes has a machine that stops working frequently. I’ve suggested that they just use a separate air pump instead. In one of the rock forum posts I saw instructions on how to make your own geyser from a chunk of brass. My question is this: is there a source for a readymade geyser that can be attached to an independent air pump and tubing? Do aquarium shops have these? Thanks fir your help!
Post by Drummond Island Rocks on Jan 26, 2021 8:56:04 GMT -5
stonemon
Member since January 2017
Post by stonemon on Jan 26, 2021 8:59:03 GMT -5
Welcome to the forum Claire!
Post by Pat on Jan 26, 2021 9:40:36 GMT -5
Good morning! Welcome from California!
Post by manofglass on Jan 26, 2021 9:45:31 GMT -5
Welcome from Michigan
Post by Fossilman on Jan 26, 2021 10:54:52 GMT -5
Welcome
rocket
Quality slabs for quality cabs in 2022
Member since September 2020
Post by rocket on Jan 26, 2021 15:02:16 GMT -5
That’s a great question...hope someone has a great answer...
Post by jasoninsd on Jan 26, 2021 15:36:45 GMT -5
Welcome to the forum from South Dakota Claire! It looks like Chuck ( Drummond Island Rocks) has some great leads on a solution for you. +1 for Chuck!
Post by rmf on Jan 26, 2021 16:17:31 GMT -5
I have a titan with a 35 yr old geyser. when the pump failed it was cheaper to get an air pump for a fish tank. then my geyser did not work well. I got frustrated and put my big air compressor on it and pushed 100psi through the geyser in clean water. after about 10 min it gave me no more problems on the fish tank pump. Be sure the geyser is pulled out of the water when not used, dont let it set in dirty water long and let it blow out the water in it each time you stop using it.
Post by rmf on Jan 26, 2021 16:18:28 GMT -5
someone on the forum has a link for a supplier that sells a geyser cheaper the DP. I just can't remember who.
Post by rockpickerforever on Jan 26, 2021 18:14:41 GMT -5
Kingsley North sells the replacement brass geyser for $18.95 plus shipping. I don't have wheels, just a flat lap, so I cannot speak to how well this works. I have, however, used this company for other things, and would recommend them.
Brass geyser for Wheel Wetter replacement
It is in stock now.
Post by TheRock on Mar 1, 2021 14:21:29 GMT -5
Welcome to RTH Forum from S/W Michigan! ~Duke
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Mar 1, 2021 15:06:40 GMT -5
The geysers themselves would be usable with an air pump. The most likely problem with the club set up us lack of oil on the leather. If a couple of drops don't help take the pump apart, it is easy. Take the screw out of the leathers get them oily reassemble. The other main issue being the belt.
Post by opalpyrexia on Mar 1, 2021 16:35:04 GMT -5
Welcome from Washington.
If your art center has an ultrasonic cleaner you could give that a try at clearing the blockage. After you have a functioning geyser, just before turning off your cabbing machine, momentarily blocking the geyser spray with a finger will help to blow out any grit that could potentially cause trouble.
