neural
Member since November 2019
Post by neural on Apr 13, 2021 17:58:59 GMT -5
Just assessing the condition of my tools. I have a Smith's little torch (propane/oxy), and I'm trying to figure out what I can fix, and what needs to be replaced completely. The tip I used the most in 2010/2011 was the #7. Just wondering if the appearance of the tips is the way they should be, and if not, can it be brushed off with a brass wire brush? Or is it a complete loss at this point? thanks
standles
Well all I got was a rock ... Cool!
Member since February 2021
Post by standles on Apr 13, 2021 19:03:03 GMT -5
If it is clogged boil in some water and blow out the debris from tip back with compressed air. If it is the soot and buildup on outside I don't worry about that on my other torches. If it bothers you take some steel wool and scrub it off. My heavy cutting and brazing rig stays sooted up. I clean the tips with tip files (much larger holes) and sandpaper the face then go on.
