Post by miket on May 6, 2021 13:48:17 GMT -5
So everyone went to the store and I thought I'd slab a rock...and this happened. Was it me or a defective blade, and has this happened to anyone else? Thanks.
Post by Sabre52 on May 6, 2021 14:02:32 GMT -5
Man that looks like a defective blade to me. Edge where the sintered diamond joins the core looks like there were problems with the interface.In many many years of sawing rocks I've never had that happen with a blade. However Diamond Pacific made a defective run of sintered diamond grinding wheels one time where the sintered diamond part just peeled off just the like edge of your blade did. This was due to water getting under the diamond section causing it to rust free. If you were using water coolant that could be the problem with your blade. The edge of the larger section that broke off does look a bit rusty in the pic.
Post by miket on May 6, 2021 14:11:08 GMT -5
Man that looks like a defective blade to me. Edge where the sintered diamond joins the core looks like there were problems with the interface.In many many years of sawing rocks I've never had that happen with a blade. However Diamond Pacific made a defective run of sintered diamond grinding wheels one time where the sintered diamond part just peeled off just the like edge of your blade did. This was due to water getting under the diamond section causing it to rust free. If you were using water coolant that could be the problem with your blade. The edge of the larger section that broke off does look a bit rusty in the pic. Thanks Mel. The thing is that it was a new blade I just picked up from the hardware store to cut some tile. It kept breaking tiles so maybe it was the blade... Last time I get one of those! 🙄
Post by jasoninsd on May 6, 2021 14:36:56 GMT -5
Holy smokes...it's a wonder you weren't injured by that dang thing!!!
Post by miket on May 6, 2021 14:43:00 GMT -5
Holy smokes...it's a wonder you weren't injured by that dang thing!!! Yeah it started wobbling and shaking
Post by jasoninsd on May 6, 2021 14:46:07 GMT -5
Holy smokes...it's a wonder you weren't injured by that dang thing!!! Yeah it started wobbling and shaking That's when you start ducking and running!
Post by Pat on May 6, 2021 15:02:11 GMT -5
Scary! Blades shouldn’t do that. Glad you weren’t hurt.
Post by miket on May 6, 2021 15:10:58 GMT -5
Post by miket on May 6, 2021 15:11:50 GMT -5
Scary! Blades shouldn’t do that. Glad you weren’t hurt. Thanks! Hoping it was the blade and not the saw.
saxplayer
Member since March 2018
Post by saxplayer on May 6, 2021 15:31:04 GMT -5
Man that looks like a defective blade to me. Edge where the sintered diamond joins the core looks like there were problems with the interface.In many many years of sawing rocks I've never had that happen with a blade. However Diamond Pacific made a defective run of sintered diamond grinding wheels one time where the sintered diamond part just peeled off just the like edge of your blade did. This was due to water getting under the diamond section causing it to rust free. If you were using water coolant that could be the problem with your blade. The edge of the larger section that broke off does look a bit rusty in the pic. this has happened to me 6 times now. Same situation - just waiting for it to tear my finger off. Therefore - I bought a rock saw. i'm done with tile saws.
Post by mohs on May 6, 2021 15:37:05 GMT -5
yeah Mike I munched a MK Blade pretty sure ut was a MK using it on my WorkForce TiLe Saw and jamming too large of rock in to it blade spinning to fast & inexperience on my part was contributing factors it was expensive blade I wasn't real pleased with myself...m stly think I still have it if so...I'll post a pic hope they git ya a birthday blade Happy Birthday !
Post by miket on May 6, 2021 15:51:48 GMT -5
yeah Mike I munched a MK Blade pretty sure ut was a MK using it on my WorkForce TiLe Saw and jamming too large of rock in to it blade spinning to fast & inexperience on my part was contributing factors it was expensive blade I wasn't real pleased with myself...m stly think I still have it if so...I'll post a pic hope they git ya a birthday blade Happy Birthday ! Maybe it was me then... And thanks!
Post by Rockoonz on May 6, 2021 16:13:18 GMT -5
I had a rock take a bite out of a sintered lapidary blade in a lapidary saw awhile back, in my case I wandered away while it was cutting and my high maintennance slab saw stalled the blade, but the auto feed kept going and munched the blade. It bent the blade pretty severely before it snapped, doesn't look the same as yours. Other than a faulty blade, I suppose if you were using the side of the blade a lot to shape rocks it may have contributed to the failure.
Post by miket on May 6, 2021 16:18:49 GMT -5
I had a rock take a bite out of a sintered lapidary blade in a lapidary saw awhile back, in my case I wandered away while it was cutting and my high maintennance slab saw stalled the blade, but the auto feed kept going and munched the blade. It bent the blade pretty severely before it snapped, doesn't look the same as yours. Other than a faulty blade, I suppose if you were using the side of the blade a lot to shape rocks it may have contributed to the failure. Thanks for answering, but no, just cutting a rock.
Post by mohs on May 6, 2021 16:20:39 GMT -5
Not sure that was you, Mike this was definitely me diammodns’nrust & broken trust Somehow kept the heart intact ....
neural
Member since November 2019
Post by neural on May 6, 2021 17:46:29 GMT -5
Silly question, but does the blade have a specific direction it is supposed to rotate in?
(have seen some odd stuff happen in that regard)
Post by stefan on May 6, 2021 17:56:39 GMT -5
I have used a tile saw for 15 years now and never have seen this kind of failure. I even had a chunk of lace agate break funny and pinch the saw blade between the table and the rock causing the saw to stall and pop a breaker, and the blade got a link in it but held. I took a hammer and work the blade back to true and use it for real soft rock (as I'm afraid hard stuff may split the blade like what happened to you lol). I would say that unless you were really horsing that blade that is defective defective defective.
Post by rockjunquie on May 6, 2021 18:19:56 GMT -5
Oh man! I'm so glad you are ok. That could have ended badly.
My son and I have used the skilsaw tile saw for a long time with various blades and rocks and have never had a problem. I'm thinking it was a bad blade, but who knows. I'm just glad no one got hurt.
Post by hummingbirdstones on May 6, 2021 18:41:24 GMT -5
Holy moley, Mike!
I'm so glad you didn't get hurt. If it was a new blade, it was defective. There's no way that should have happened. We don't have a tile saw, but I've never seen a blade do that.
Post by Garage Rocker on May 6, 2021 18:43:39 GMT -5
