Post by toiv0 on May 22, 2021 15:04:22 GMT -5
Post by toiv0 on May 22, 2021 16:12:23 GMT -5
26 rpm, thinking too slow? jamesp
salpal48
Member since March 2015
Post by salpal48 on May 22, 2021 20:30:12 GMT -5
The Drum Looks like a 40 LB to me
Post by oregon on May 22, 2021 21:22:52 GMT -5
The Drum Looks like a 40 LB to me yep, looks like a diamond pacific 40t to me...
Post by jamesp on May 23, 2021 7:19:56 GMT -5
26 rpm, thinking too slow? jamesp no, not too slow 1 - the bigger the barrel the higher the fall within(effects impact damage) 2 - and the faster the surface speed at given rpm(also effects impact damage) These 2 factors multiply(not add but multiply) themselves in some way as barrel gets bigger. For a large 9 inch barrel diameter 26 rpm is fast enough Billy. surface speed is 61 feet/min at 26 rpm A 4" barrel only does does 27 feet and a 6" does 41 feet at 26. And there is way more chances for impact damage as the barrel gets bigger. Take it to the extreme - 1 inch rocks in a 4" barrel verses 1" rocks in a 36 inch barrel both at same rpm - bet your life the 36" barrel is a much more violent tumble.
