Post by HankRocks on Jun 25, 2021 20:13:31 GMT -5
Has anyone ever seen a parts diagram for a UV-18 Vibratory Tumbler? I ordered a replacement motor for mine and it looks to be a lot of trouble to replace as the new motor is completely different. What I was wondering whether or not the UV-18 I have which I bought used had been modified to fit the current motor. A parts diagram would be useful to see that mine is factory original or modified.
Thanks Henry
Post by jasoninsd on Jun 27, 2021 20:26:50 GMT -5
Hey Henry,
I did a search online and couldn't find anything. I found a contact email from Thumler's website...maybe they've got something with regards to a parts diagram they could send you:
Contact us today at t-tumbler@thumlerstumbler.com
(http://www.thumlerstumbler.com/contact.html)
Post by Rockoonz on Jun 28, 2021 10:32:10 GMT -5
I imagine Thumlers may have improved their online communication with c0vid and all, but my personal experience with them has been that they are old school and are more responsive by phone. I am definitely curious how you resolve this. our older UV10 IND of the two had the center stud detach itself from the base, so it needs repair, possibly parts from them, soon as I can get past more pressing chores and find the box it's packed in.
Post by amygdule on Jun 28, 2021 11:54:49 GMT -5
HankRocks, Here's a few pictures of an old UV-18 that I purchased new about 25 years ago. Hope this helps. Good luck with your repair.
pizzano
Member since February 2018
Post by pizzano on Jun 28, 2021 13:16:26 GMT -5
Has anyone ever seen a parts diagram for a UV-18 Vibratory Tumbler? I ordered a replacement motor for mine and it looks to be a lot of trouble to replace as the new motor is completely different. What I was wondering whether or not the UV-18 I have which I bought used had been modified to fit the current motor. A parts diagram would be useful to see that mine is factory original or modified. Thanks Henry I both E-mailed and called Tru Square Metal Products recently and received awesome support....: We are available to help via the phone if necessary 1-800-225-1017Related to this recent thread here at RTH.......: forum.rocktumblinghobby.com/thread/95698/uv-10-center-post-replacement?page=1&scrollTo=1169609If he is available, ask for Garris and tell him you are a member of the RTH forum........He'll light up instantly.....very knowledgeable guy....!
Post by HankRocks on Jun 28, 2021 13:44:56 GMT -5
amygdule, pizzano Problem solved, I think. When I originally talked to Tru-Square about a replacement motor, he asked what type UV-18. I was not sure so he asked what is the color of the stripe on the barrel? told him it was yellow...(see where this is going) . So no problem so they had the replacement motor and had one shipped to me. When the motor arrived, I just knew it would not work. The two motor flange pieces would not accommodate the new motor studs. So I called back and explained the situation. It turns out I have the base for the Industrial(blue bowl) with a yellow bowl so they had sent me the wrong motor. That was corrected and they are sending the correct replacement motor and I will return the incorrect motor. All I can figure is that the original owner had somewhere along the way swapped out the bowl. He did mention that he had two bowls but we have never been able to locate it even after I searched several nooks and crannies in his Shop and Shed. It would make sense that if it was found it would be a "blue-stripe" bowl. Anyway, thanks for the responses. Hopefully in a week or so I will be back in the polishing business.
Post by mohs on Jun 28, 2021 14:22:13 GMT -5
dang! a 50/ 50 chance and it wrong 83.7 % of the times. and ya knohs how this ends... m hs its like the Matrix msoty
