rrod
Member since December 2020
Post by rrod on Jul 14, 2021 11:50:49 GMT -5
I had some #61 rapid polish laying around so I thought I might give my Burris Creek jaspers an extra bit of shine. But after 3 days so far, all it has done is take off the shine that I had previously gotten from TXP. Seems like people have had success with 'rapid' in vibes, but am I being foolish to try it in a rotary?
My experience with TXP was that even after 1 day it was shining things up significantly after AO1000, so it's very odd to me that the finer-grained polish is just messing things up so far…
agatemaggot
Member since August 2006
Post by agatemaggot on Jul 14, 2021 12:06:13 GMT -5
Could the stone be scratching itself and removing the previous shine ?
rrod
Post by rrod on Jul 14, 2021 12:34:11 GMT -5
Could the stone be scratching itself and removing the previous shine ? There's only 4 stones, about 1-1.5" each, in the 3lb Thumler barrel, and the rest is small media that is well-rounded.
Post by perkins17 on Jul 14, 2021 18:20:31 GMT -5
I have never used rapid polish but instead have used aluminum oxide polish. Could the lack of shine possibly be fixed by a quick burnishing? I would recommend trying that if it is dull at the end of the cycle.
Post by perkins17 on Jul 14, 2021 18:21:13 GMT -5
If that doesn't work, maybe try moving back to the txp polish.
rrod
Post by rrod on Jul 14, 2021 21:38:59 GMT -5
I have never used rapid polish but instead have used aluminum oxide polish. Could the lack of shine possibly be fixed by a quick burnishing? I would recommend trying that if it is dull at the end of the cycle. Rapid polish is AO. I think it's something like 0.3 micron. Hence why I'm a bit confused by how it's going :/
agatemaggot
Post by agatemaggot on Jul 15, 2021 10:20:06 GMT -5
In 3 days those few stones might do a lot of rubbing together .
Post by perkins17 on Jul 15, 2021 11:00:27 GMT -5
That's interesting. Maybe add more of the rapid polish? I don't see how moving to a finer polish would remove the other polish. I agree with you, that probably shouldn't have happened.
