Post by hummingbirdstones on Aug 22, 2021 19:05:38 GMT -5
Now that Lonnie's has closed, does anyone in the Valley know of a supply house that sells investment and other smithing supplies?
A friend who is a goldsmith was just over and he asked if we knew of anywhere around here. He used to get his supplies at Lonnie's.
jimaz
Member since July 2018
Post by jimaz on Aug 22, 2021 19:23:35 GMT -5
Post by mohs on Aug 22, 2021 19:35:07 GMT -5
Hi Robin
I'm not 100% sure what your trying zero in on
S & J Jewelry Supply is pretty good lapidary source
2725 N 24th St #1,
602 956 0189
The proprietor of S&J used to work at Lonnies's so your friend may know of him good or bad
____________________________________________________________
There a jewelry lapidary supply house
on basically 17th ave Camelback Rd it as a crazy name like
Lambert Nietzert
it been there long time I've done some biz
Finding King in Scottsdale as lots of stuff 2933 N Hayden Rd #2 480 990 7690
of course as you probably know internet as the best prices mostly likely but in pinch these places have been known to deliver...
gemfeller
Member since June 2011
Post by gemfeller on Aug 22, 2021 19:39:27 GMT -5
Post by mohs on Aug 22, 2021 21:23:12 GMT -5
they are pretty good Rick especially in a pinch and just down the street from me belts, dops, wheels, findings, used equipment, saw lube, lot of silversmith stuff to I would think
Post by hummingbirdstones on Aug 22, 2021 22:20:11 GMT -5
Basically, he's getting low on investment for casting and was looking for somewhere he can drive to to buy more when he needs to. He does a lot of casting and with Lonnie's closed he was at a loss for where to get some without ordering it. Shipping on boxes of investment is astronomical -- they're heavy! Plus I'm sure he'll have a need for other jewelry making stuff on occasion.
Post by mohs on Aug 22, 2021 22:48:40 GMT -5
Yes as I recall Lonnie’s Had lots of that casting equipment A lot of it was foreign to me Having never experiment with that craft Alto I was more than interested
Your friend probably know The sources I listed
After Lonnie's that may be a tough gig Finding that sort of suppliers
as mentioned maybe Tucson would be a source
Let us know if he successful...
Post by hummingbirdstones on Aug 22, 2021 22:53:47 GMT -5
Yes as I recall Lonnie’s Had lots of that casting equipment A lot of it was foreign to me Having never experiment with that craft Alto I was more than interested Your friend probably know The sources I listed After Lonnie's that may be a tough gig Finding that sort of suppliers as mentioned maybe Tucson would be a source Let us know if he successful... S&J's has investment, so he should be good with that. Tucson's a bit of a drive from Chino just to buy investment.
Post by mohs on Aug 22, 2021 23:03:04 GMT -5
i suppose but I don't even know what investments are ?
and now that i;m retired done wish I had learned ha
Post by hummingbirdstones on Aug 23, 2021 9:49:33 GMT -5
i suppose but I don't even know what investments are ? and now that i;m retired done wish I had learned ha Investment is kind of like plaster of paris. It's what is used to pour around your wax that you want to cast into a piece of jewelry.
The process simplified goes like this: Make your wax model and sprue it (connect it with wax wires so the molten metal can get in) to the base of your metal casting flask. Fill the flask will investment (the powder investment that is mixed with water). Let it set and then burn out the wax in a "burn-out" oven (kiln). When the wax is burned out, then you cast the molten metal into the flask, the metal fills the void left by the burned out wax and you have your piece of jewelry.
Post by mohs on Aug 23, 2021 10:27:00 GMT -5
Right on hummingbirds ! The ancient Greeks would bronze cast their metal ramming spear on the prow for their triemes. Done on the beach using the lost wax method well that what I read one time probably in an encyclo hope your friend as success heave metal shell cast...
