Post by Son Of Beach on Sept 30, 2021 16:32:44 GMT -5
I have an 20 year old Old Navy single strap bag similar to this one that I never had a use for and now it's the perfect little rock sack. Not good for much over 15 lbs though. I probably have to upgrade soon, curious what others found success with.
Post by Starguy on Sept 30, 2021 17:50:45 GMT -5
Son Of Beach I like that. I usually use a 5 gallon bucket because it’s easy to set down while I wander around looking. That bag would be easy to set down too. I would hang something colorful on it so it’s easier to see. I would worry that I would lose it because of the earth tone colors. It looks pretty comfortable.
Post by jasoninsd on Sept 30, 2021 17:54:27 GMT -5
I use a sturdy backpack...until it wears out...then I get another "sturdy" one. And cargo pants...always cargo pants! I'll walk along putting rocks into my cargo pockets until they start pulling my pants down (a belt is essential also), then I stop and transfer from pocket to backpack...then repeat until I can barely lift the backpack...then I head back to the truck, unload and start the process all over again.
mud
Member since May 2018
Post by mud on Sept 30, 2021 18:35:25 GMT -5
Interesting question!
For me, it depends. If I'm only planning to collect 2-3 pounds (ok, 5-6 pounds) of rock, I like to use an old camera bag (or an old camcorder bag if I need something just a little bigger). These tend to be tough and readily available (i.e. free/cheap). Otherwise, yeah, 5 gallon buckets or backpacks.
Post by pauls on Sept 30, 2021 18:37:43 GMT -5
I use old school backpacks, they are reasonably rugged are padded to stop books digging into kids backs, (that works for rocks as well) and cheap from the thrift shop. Also Jason"s method of filling pockets then transferring to backpack. I have seen a couple of blokes at Agate creek who used a hessian wheat sack, cut a neck hole in the middle of the sack, stitch up both ends and wear the sack like a poncho, with rocks in the sack ends evenly distributed between front and back. They swore it was the only way to do it.
Post by HankRocks on Sept 30, 2021 18:54:01 GMT -5
I usually use a two bucket method, 2 to 3 gallon range. One will have a couple of old screwdrivers for prying, a rock hammer, maybe a chisel and a spray bottle of water. It easier to walk with a balanced load. Usually wear one of my kids old backpacks for food, drinking water, camera and such. It also depends on the material, is it dispersed over wide area or is it a small outcrop.
Post by RWA3006 on Sept 30, 2021 19:00:24 GMT -5
I usually take two five gallon buckets in order to stay balanced and wife takes a single for herself.
Benathema
Member since November 2019
Post by Benathema on Sept 30, 2021 19:02:34 GMT -5
I've been using one of those cyclists water pouch backpacks. It's not very big, but I took the water bladder thing out of it. I stocked it up based on my solo adventures in BFE Rockies of CO. It has enough room for my FA kit, and some other supplies (emergency blanket, compass, flashlights, Paracord, etc), plus side pouches for water bottles. It clasps in the front, which I've found is pretty much mandatory at this point. It has a waist strap too, but I have that all tied and twisted up out of the way. I run with a fanny pack on my hip for quick collection, then periodically transfer to the backpack. I have to eat the snacks and drinks to make room for more rocks. Fully loaded comes in at about 35-40 pounds, so it keeps me from overloading myself.
Post by Son Of Beach on Sept 30, 2021 19:39:54 GMT -5
Hey...that guy looks just like you!
Post by Son Of Beach on Sept 30, 2021 19:43:34 GMT -5
I decided that I would look like a bit of a weenie at the beach with a five bucket so I decided against it. Apparently I have a blind spot however, because I'm scouring with essentially a man purse lol. Its really not that bad...you have to swap shoulders every once in a while.
Post by Son Of Beach on Sept 30, 2021 19:47:05 GMT -5
The pockets of my swimsuit always get overfilled...and there is no belt to help with what's coming after. There is only one spot where I can walk back and forth reasonably otherwise its a good 30 min walk back and forth...I'm jealous
Post by Son Of Beach on Sept 30, 2021 19:48:23 GMT -5
I might eventually try something like this just feel like I'd tear my shoulder eventually pumping rocks over my back...dunno.
Post by jasoninsd on Sept 30, 2021 19:55:10 GMT -5
I use a sturdy backpack...until it wears out...then I get another "sturdy" one. And cargo pants...always cargo pants! I'll walk along putting rocks into my cargo pockets until they start pulling my pants down (a belt is essential also), then I stop and transfer from pocket to backpack...then repeat until I can barely lift the backpack...then I head back to the truck, unload and start the process all over again. The pockets of my swimsuit always get overfilled...and there is no belt to help with what's coming after. There is only one spot where I can walk back and forth reasonably otherwise its a good 30 min walk back and forth...I'm jealous
You just have to get suspenders on your swimsuit!
Post by amygdule on Sept 30, 2021 20:11:47 GMT -5
I like my US Army rucksack. I have loaded up 70 lbs before. That's kind of heavy. That big rock is a huge concretion with a log of Teredo wood in it.
Post by Son Of Beach on Sept 30, 2021 20:43:27 GMT -5
You just have to get suspenders on your swimsuit! A good way to make sure nobody comes near your search
quartzilla
Member since April 2020
Post by quartzilla on Sept 30, 2021 21:23:05 GMT -5
Lol Jason! As far as backpacks go I use a medium duty one that has the strap that goes around your waist to help balance the support. As far as buckets I like the canvas style ones that usually have a rope handle, sometimes you see them hanging from the back of Linemen’s and electricians trucks. Pretty sturdy and the fold up flat when not in use.
Post by mohs on Sept 30, 2021 22:30:32 GMT -5
Ho Ho Ha Ha He He Hah Hah
Post by Peruano on Oct 1, 2021 5:33:10 GMT -5
I scored a yellow bowling ball bag at a yard sale that works great ( high visibility; large enough capacity, and tough construction), but believe it or not I have a heavy canvas bag that says Macys across it that is my daily driver. It makes me feel stylish in the rough. Ironically the Macys bag is an almost identical knockoff of the classic LLBean marine canvas bag and a really good collecting bag.
Post by fernwood on Oct 1, 2021 6:21:30 GMT -5
When collecting on my land, I use my ATV. Put 2 five gallon pails and an ice cream pail in the back rack. Use the ice cream pail for short trips from ATV. Then empty it into the larger pails.
When collecting elsewhere, I use a waist bag and a heavy duty, military surplus back pack. I like the back pack, as it has many pockets designed for ammo and other small things, plus several large compartments. Has lots of cushioning on back and straps, as it was designed to hold 35 lbs. comfortably when walking/running. Also has loops where water bottles can be attached and an insulated water bottle compartment.
Use the waist bag for my phone, keys, Leatherman lip balm and other small items.
Post by RickB on Oct 1, 2021 9:40:07 GMT -5
This backpack is on my wish list. Edit: No pack but have used Coke flats, milk crates, 5 gallon buckets, kitty litter buckets, wheel barrow or hand truck and a cement mixing tub with ropes on it to drag things back with.
