Post by 1dave on Nov 12, 2021 14:15:02 GMT -5
![1.1-Reading](https://res.cloudinary.com/crosbj/image/upload/v1636824083/Charts/Basic-Education/1.1-HappyReading_o6b7of.jpg)
The Five Finger Rule
![5-Finger](https://res.cloudinary.com/crosbj/image/upload/v1636826598/Charts/Basic-Education/5-Finger-Rule_jfq9mh.jpg)
www.justrightreads.com/reading-levels-explained
Reading Levels Explained
All of the different types of reading levels can be overwhelming.
If you are unsure of your child’s level, use the chart below to find out which letter or number corresponds to your child’s grade level. Scroll down to find more information about each of the leveling systems.
Grade Level Comparisons
GRL = GUIDED READING LEVEL
Kindergarten: A - C
1st Grade: C - I
2nd Grade: I - M
3rd Grade: M - P
4th Grade: P - S
5th Grade: S - V
6th Grade: V - Y
AR = ACCELERATED READER
Kindergarten: 0.1 - 0.9
1st Grade: 1.0 - 1.9
2nd Grade: 2.0 - 2.9
3rd Grade: 3.0 - 3.9
4th Grade: 4.0 - 4.9
5th Grade: 5.0 - 5.9
6th Grade: 6.0 - 6.9
DRA = DEVELOPMENTAL READING ASSESSMENT
Kindergarten: A - 4
1st Grade: 4 - 16
2nd Grade: 16 - 24
3rd Grade: 24 - 38
4th Grade: 38 - 40
5th Grade: 40 - 50
6th Grade: 50 - 60
7th & 8th Grade: 60 - 80
lEXILE MEASUREMENT LEVELS
Kindergarten: BR40L - 230L
1st Grade: BR120L - 295L
2nd Grade: 107L - 545L
3rd Grade: 415L - 760L
4th Grade: 635L - 950L
5th Grade: 770L - 1080L
6th Grade: 855L - 1165L
7th Grade: 925L +
![Chart](https://res.cloudinary.com/crosbj/image/upload/v1636744024/Charts/ReadingComp_xddney.jpg)
Reading Assessment Resources
Guided Reading Levels (GRL):
Guided reading levels (GRL) provided by the Scholastic Book Wizard are said to be equivalent to Fountas and Pinnell levels.
Although we have found that a couple levels do not match, they are close enough we will follow Scholastic’s guided reading levels. If Fountas and Pinnell running records are the assessment your school or district uses, you may use our guided reading levels (GRL) to help you to find Just Right Reads!
Accelerated Reader (AR) ATOS Level:
Student independent reading levels can be measured using the Renaissance’s computer adaptive test which means the test adjusts as your child responds to each question. If they answer a question correctly, the next question will be more advanced. If they answer a question incorrectly, the question that follows will be easier. If this assessment is your school or districts preference, your can find more information here.
Text Complexity, ATOS, and Lexile Measures
ATOS Conversion Chart
Developmental Reading Assessment (DRA):
Developmental Reading Assessment levels (DRA) come from the reading assessment tool measuring your child’s reading accuracy, fluency, and comprehension. The numbers jump by twos, fours, and tens. Example: 12, 20, 24, 28, 30
Lexile Measurement:
Another popular system used to measure a child’s reading ability and to level children’s books is the Lexile Framework. Lexile measures provide a child’s numbered reading level/ability, and when using the Lexile Framework which levels books on text complexity, we can “forecast reading comprehension”. This is what we would call a Just Right Book! Yo can find more information about the Lexile Framework here and here.
