lucy
Becoming obsessed with rocks
Member since June 2022
Post by lucy on Jun 17, 2022 22:44:34 GMT -5
Hello all!! I'm brand-spankin' new to this hobby and am quite excited about it! I've spent a couple months researching rock tumbling before I ordered my first tumbler, a used Lortone 3a, which should arrive on Wednesday! <Insert happy dance here!>. I've been reading a whole lot of posts in the forum and have learned a lot from you all already!
My question is this: Does the area selected for the tumbler have to have heat or air conditioning? It seems most people have theirs in a garage or basement. I've never had a garage, and most houses in Arkansas don't have basements. We do have an outdoor shop that is walled and covered, but it can get as hot as Dante's inferno here. I don't know if that is recommended for a tumbler or if I need to reorganize to find it a "home" inside the house somewhere where the noise won't bother us.
What do y'all think? Thanks!! π
Post by vegasjames on Jun 18, 2022 1:14:23 GMT -5
Welcome to the forum.
jimmie
Member since August 2021
Post by jimmie on Jun 18, 2022 7:43:06 GMT -5
Shouldnβt matter, but donβt want to overheat the lil lortone motor. My shop gets hot in the summer, getting me ready for the afterlife.
jimaz
Member since July 2018
Post by jimaz on Jun 18, 2022 10:02:18 GMT -5
I have a Lortone 45C that is in a garage storeroom and run it year round. The room does stay a little cooler than outside in summer and warmer in the winter. Iβm in southern Arizona so it does get quite hot. Currently have had several days 100+, actually 110 a couple of days ago. I would not attempt to run the tumbler in prolonged freezing weather because of the possibility of the slurry freezing.
lucy
Post by lucy on Jun 18, 2022 14:42:44 GMT -5
Shouldnβt matter, but donβt want to overheat the lil lortone motor. My shop gets hot in the summer, getting me ready for the afterlife. I understand about getting ready for the afterlife!! Lol
lucy
Post by lucy on Jun 18, 2022 14:43:50 GMT -5
I have a Lortone 45C that is in a garage storeroom and run it year round. The room does stay a little cooler than outside in summer and warmer in the winter. Iβm in southern Arizona so it does get quite hot. Currently have had several days 100+, actually 110 a couple of days ago. I would not attempt to run the tumbler in prolonged freezing weather because of the possibility of the slurry freezing. Thanks for the tips! It's hot here, but the humidity is so high it can feel hard to breathe! But the pointers are always helpful!
Post by Pat on Jun 18, 2022 14:51:23 GMT -5
Welcome from California. Iβm not a tumbler, but there are many tumbling experts here. Not me!
dshanpnw
Member since December 2020
Post by dshanpnw on Jun 18, 2022 16:19:05 GMT -5
Welcome from Washington State. Great question. The shop should work. I think the 3A will do fine in the heat, but the super cold, I've heard about slurry freezing. Maybe take it in the house in winter. You'll feel the motor gets hot, but I think it should be okay. We are still waiting for the warmer weather here in the Northwest. Good luck.
Post by stefan on Jun 18, 2022 17:42:20 GMT -5
My motors run about 120 degrees in my cool basement. These motors are thermally protected so they should shut down before burning up. If it is a concern I would have a fan blowing across it to remove excessive heat build up. I have been tumbling for 17 years now and never burned up a motor (even from some cheap Chinese tumblers I ran for a while).
Post by jasoninsd on Jun 18, 2022 18:30:37 GMT -5
Hey Lucy! Welcome to the forum from South Dakota!
Post by hummingbirdstones on Jun 18, 2022 18:33:12 GMT -5
Welcome from Northern Arizona!
lucy
Post by lucy on Jun 18, 2022 20:12:37 GMT -5
Welcome from Washington State. Great question. The shop should work. I think the 3A will do fine in the heat, but the super cold, I've heard about slurry freezing. Maybe take it in the house in winter. You'll feel the motor gets hot, but I think it should be okay. We are still waiting for the warmer weather here in the Northwest. Good luck. Thanks. I hope the warm weather comes soon for you! Warm, but not too hot. π
lucy
Post by lucy on Jun 18, 2022 20:13:55 GMT -5
My motors run about 120 degrees in my cool basement. These motors are thermally protected so they should shut down before burning up. If it is a concern I would have a fan blowing across it to remove excessive heat build up. I have been tumbling for 17 years now and never burned up a motor (even from some cheap Chinese tumblers I ran for a while). Tumbling for 17 years! That's awesome! I appreciate your tips and knowledge.
nursetumbler
Member since February 2022
Post by nursetumbler on Jun 19, 2022 9:25:24 GMT -5
Hi lucyWelcome from Michigan. Ask me hiw I can attest to slurry freezing π₯Ά π Nothing happened to the rocks but it took awhile for it to thaw out so I could clean it out and start new. When I did I was going to start it with car windsheild washer fluid but I didn't know if whatever chemical was in there to make it not freeze would hurt the process so I just brought them inside and tumbled them in my craft room. I would suspect that you don't get as hard of freezes as Michigan but then again I've not ever been in Arkansas before. Mine are currently in the belly of my Motorhome and currently sit on the west side so it gets direct sun for many hours and we've had a few days recently of mid to upper 90's. The experts here won't steer you wrong. Again welcome from Michigan Kelly
lucy
Post by lucy on Jun 19, 2022 20:14:03 GMT -5
Hi lucyWelcome from Michigan. Ask me hiw I can attest to slurry freezing π₯Ά π Nothing happened to the rocks but it took awhile for it to thaw out so I could clean it out and start new. When I did I was going to start it with car windsheild washer fluid but I didn't know if whatever chemical was in there to make it not freeze would hurt the process so I just brought them inside and tumbled them in my craft room. I would suspect that you don't get as hard of freezes as Michigan but then again I've not ever been in Arkansas before. Mine are currently in the belly of my Motorhome and currently sit on the west side so it gets direct sun for many hours and we've had a few days recently of mid to upper 90's. The experts here won't steer you wrong. Again welcome from Michigan Kelly Thanks for the welcome! I haven't been to Michigan, but from what I hear, it get *lots* colder there for a lot longer than here! This seems like such a friendly just-wanna-help or cheer you on kind of place!
Post by jasoninsd on Jun 19, 2022 20:52:41 GMT -5
Hi lucyWelcome from Michigan. Ask me hiw I can attest to slurry freezing π₯Ά π Nothing happened to the rocks but it took awhile for it to thaw out so I could clean it out and start new. When I did I was going to start it with car windsheild washer fluid but I didn't know if whatever chemical was in there to make it not freeze would hurt the process so I just brought them inside and tumbled them in my craft room. I would suspect that you don't get as hard of freezes as Michigan but then again I've not ever been in Arkansas before. Mine are currently in the belly of my Motorhome and currently sit on the west side so it gets direct sun for many hours and we've had a few days recently of mid to upper 90's. The experts here won't steer you wrong. Again welcome from Michigan Kelly This seems like such a friendly just-wanna-help or cheer you on kind of place!
lucy
Post by lucy on Jun 19, 2022 20:55:38 GMT -5
Jasoninsd
This cracked me up! π
The more I read on here, the more I think I've found my people!
Post by jasoninsd on Jun 19, 2022 21:07:55 GMT -5
Jasoninsd This cracked me up! π The more I read on here, the more I think I've found my people! I love it when a plan comes together! LOL If you care for others...and are somewhere between slightly and completely off your "ROCKer"...then you're amongst friends and like souls!
nursetumbler
Post by nursetumbler on Jun 19, 2022 21:12:36 GMT -5
Jasoninsd This cracked me up! π The more I read on here, the more I think I've found my people! lucyYou can tag people using @ then their name which you can get off their profile or touch their name and that will also take you to their profile. jasoninsd will keep you in stitches. Lol Yes Michigan is cold most years from Oct up to and sometimes including May but if you don't like it wait 15 minutes because most times it will change. We fashion Halloween costumes around snow suits and you can very easily feel all 4 seasons in 1 day. Lol.
Post by jasoninsd on Jun 19, 2022 21:18:14 GMT -5
Jasoninsd This cracked me up! π The more I read on here, the more I think I've found my people! lucy You can tag people using @ then their name which you can get off their profile or touch their name and that will also take you to their profile. jasoninsd will keep you in stitches. Lol Yes Michigan is cold most years from Oct up to and sometimes including May but if you don't like it wait 15 minutes because most times it will change. We fashion Halloween costumes around snow suits and you can very easily feel all 4 seasons in 1 day. Lol. Wait...was this a subtle reference to the five stitches I still have in finger from my recent rock "bite"?? LOL
