Post by woodman on Jun 19, 2022 17:42:04 GMT -5
I am cutting a Brazilian agate and wanted to cut the res4t of the agate also into slabs. This is the system I use. I cut a piece of pet wood slightly larger than the agate, using super glue I glued a piece of cardboard to the wood, 4then glued the agate to the cardboard. Both pieces were degreased before gluing. By leaving the pet wood in vise, i get parallel slabs right up to the card board.
Post by RWA3006 on Jun 19, 2022 18:02:03 GMT -5
Bob, I seem to remember you doing that trick with a piece of lumber. I'm guessing this way gives you a slightly straighter slab on the last cut?
Post by jasoninsd on Jun 19, 2022 18:29:43 GMT -5
That's genius Bob! I think I've mentioned it before...but there's a trick when installing slate on a 3-piece slate table. You can actually glue the pieces of slate together with an index card and superglue. It holds amazingly well. Super smart way not to waste material!! Way to go!
Post by woodman on Jun 19, 2022 18:38:21 GMT -5
Bob, I seem to remember you doing that trick with a piece of lumber. I'm guessing this way gives you a slightly straighter slab on the last cut? I have seen photos of the wood idea but have never done it myself. this works good for me!
Post by stardiamond on Jun 19, 2022 20:11:49 GMT -5
I tried this on a large rock and the oil turned the cardboard to mush. Small rocks, water glass. Large rocks, wood glue. Both glued to a board.
Post by woodman on Jun 19, 2022 21:12:10 GMT -5
I tried this on a large rock and the oil turned the cardboard to mush. Small rocks, water glass. Large rocks, wood glue. Both glued to a board. Did with 48 inch saw, took two of us to lift the piece to be glued on, no problems, starbond superglue!
Post by woodman on Jun 26, 2022 17:47:03 GMT -5
Fished with the cutting, miscalculated a bit, the last one ended up a bit thicker, but I have plent4y for what I am doing with these. Still glued to the host. I will put it in an oven to break the superglue bond.
