gravelgirl
Member since July 2022
Post by gravelgirl on Aug 5, 2022 11:09:06 GMT -5
I bought a used wet/dry table grinder for $77 shipped. It was totally impulsive and I really hope it’ll be an easy lapidary conversion. Has anyone tried it before? The flat wheels is 8” and the side wheel is 5”
Post by 1dave on Aug 5, 2022 12:41:21 GMT -5
No, but it looks interesting and a bargain.
Pick up a cheap (~$100) tile saw at Home Depot and you have a great starting shop.
gravelgirl
Post by gravelgirl on Aug 5, 2022 12:51:22 GMT -5
I have a tile saw, i want to play with polishing some slabs
Post by 1dave on Aug 5, 2022 13:21:20 GMT -5
A fluorescent tube overhead is a great way to see scratches that still need to be ground out. Rotate the slab 90 degrees with each change to finer grit.
rockbrain
Member since January 2022
Post by rockbrain on Aug 5, 2022 14:36:56 GMT -5
Are different grits available for the wheels?
gravelgirl
Post by gravelgirl on Aug 5, 2022 15:11:53 GMT -5
I think there’s different stones you can get, but I’ll adapt it to lapidary discs
Post by mohs on Aug 5, 2022 16:31:03 GMT -5
Welcome To RTH
I’ve messed around w/ those sharpener flat lap grinders w/ varying degree of success for lapidary work
The rpm speed is usually slow on those machines
Attaching a diamond lap disc will work
You may have to get a bit creative with how to secure the flat lap to the spindle
anyway that interesting project and as you progress that machine will come in useful
where you located ?
Ed
gravelgirl
Post by gravelgirl on Aug 5, 2022 20:25:18 GMT -5
Hi Ed, I’m in Southern Illinois.
I’ve been learning a bit about machinery lately as I work on building a larger rock tumbler. I think I might feel confident enough to even switch out the shaft and make some adjustments. It’ll just probably mean a hundred more times back and forth to the hardware store 😂
Post by greig on Aug 8, 2022 19:16:52 GMT -5
For the price, you did fine. Try it out and let us know
