Post by stardiamond on Sept 4, 2022 16:20:56 GMT -5
Assuming a 14inch saw? I only slab to make cabs so time was the only factor. Electricity used and blade wear among other factors.
I might want to sell some slabs. I know what the rough costs, I'm not trying to make anything for my time.
fencejumper
Member since May 2021
Post by fencejumper on Sept 4, 2022 17:26:36 GMT -5
Assuming a 14inch saw? I only slab to make cabs so time was the only factor. Electricity used and blade wear among other factors. I might want to sell some slabs. I know what the rough costs, I'm not trying to make anything for my time. Double the price you paid for the rock And weigh each slab
Post by Rockoonz on Sept 5, 2022 3:33:08 GMT -5
I sell good but average, common material slabs for $1/oz assuming from roughly $5/lb material, and adjust from there based on whatever the rough is selling for or when a chunk yields those rare, spectacular slabs. I also look at waste and either bust it off for tumble filler or reduce the price accordingly to what percentage is not usable.
Post by stardiamond on Sept 5, 2022 12:28:51 GMT -5
I did a poor job asking the question based on the responses. The market generally determines the selling price factored with the cost of the rough.
What I am interested in is what does it cost to cut one slab on a 14inch saw? Cost of blade/number of cuts in a blade's life. Cost of electricity based on use; rate x draw x duration of cut. I have a high electric bill that has tiered pricing. Slabbing when the a/c is running is not a good practice.
When I cut a slab to make cabs, the cost to cut is not significant. What I consider is value of cabs made vs cost of material to make them. My goal is 3 times. I want a $25 slab to produce $75 in cabs.
AzRockGeek
Member since September 2016
Post by AzRockGeek on Sept 5, 2022 13:53:03 GMT -5
What I researched long ago, they charge by the square inch, laying the slab on a quilting measuring square and see how many boxes the slab covers. I don't recall the price, somewhere between 0.25 to 0.5 cents per square. Most places had a handful of materials they would not cut due to the mess, marble, red jasper, hematite....
By my calculations at the time, not worth dealing with for me. The cost of a good blade, the oil, it do not make financial sense. If, you can have multiple saws running at the same time, you might make more then minimum wage.
Good luck.
