tumblefly
Member since September 2022
Post by tumblefly on Sept 22, 2022 8:17:10 GMT -5
Still relatively new to the hobby, and I use only 6lb barrels. Have seen some throwaway comments here and there about slight adjustments/changes people make when using 6lb and 12lb barrels (vs. the "standard" 3 lb barrel) but so far I haven't seen a thread/article that specifically lays out what these adjustments should be. Was hoping to nail down some specifics - i.e. coarser grit? less grit per pound of rock? More grit? Less time? More time? Any other "unique" issues when using larger barrels?
Thanks!
jimmie
Member since August 2021
Post by jimmie on Sept 22, 2022 8:50:50 GMT -5
You end up with more rocks to polish, the only difference I seen from 3 lb tumblers.
waterboysh
Member since April 2021
Post by waterboysh on Sept 22, 2022 11:29:05 GMT -5
I would say you can use coarser grit if you want. Anything more coarse than 60/90 might not break down in a 3lb barrel. But I've seen people say that in pretty much any bigger barrel you can use as coarse of a grit as you want and it'll break down no problem. You can also use more grit. In my 3lb, I put 3 Tbsp of 60/90; anything more and there is usually still some left after a week. In my 6lb I've experimented a bit with anywhere from 6 Tbsp to 18 Tbsp and even with the higher amount of grit, it would all break down. But I didn't notice a significant increase in work done. After playing around with it a bit I settled on 10 Tbsp.
Post by Deleted on Sept 22, 2022 11:38:20 GMT -5
jamesp would have some good advice. He does big loads! And a bit unorthodox at times too lol.
Post by As I in does tries! on Sept 25, 2022 5:09:07 GMT -5
Greetings and Welcome to RTH Forums from Bonnybridge, Scotland.
Maybe you need to look at my Aussie Lapidary Forum: Rotary Tumbling Guide see my signature.
nursetumbler
Member since February 2022
Post by nursetumbler on Sept 25, 2022 9:31:07 GMT -5
Greetings and Welcome to RTH Forums from Bonnybridge, Scotland. Maybe you need to look at my Aussie Lapidary Forum: Rotary Tumbling Guide see my signature. As I in does tries!Where can someone find your guide and what's the cost. When I bought my first grit kit from New Mexico it had a chart of grit amounts on the roteary tumbling instructions paper. The chart reads 3#=5Tbsp 4.5#=8Tbsp 6#=10Tbsp 12#=20Tbsp and 15#=25Tbsp for ALL grits. I see members say they use WAY less grit. It also says to keep your rocks wet at all times, DO NOT let them dry out for even a short period of time. I now know if it's 60/90 or 120/220 as long as they are washed really good it's not an issue. It also says tontumble each stage for a week, I laugh at that one because I have rutilated quartz thats been in since 1st of May. Seen other members that tumble for months too. Would be interested in your guide. nursetumbler
Andrewa
Post by Andrewa on Sept 25, 2022 12:43:12 GMT -5
Post by As I in does tries! on Sept 25, 2022 13:23:06 GMT -5
Greetings if you don't see my signature, maybe it's turned off. The top menu bar Portal Page - Forum - User Guide - Search - Members - My Profile - Messages - Recent - Topics - Recent Posts - Participated - Forum Rules
Click My Profile half way down the page click Edit Profile on the right hand side,
Avatar - Personal - Social - Settings - Privacy - Notifications - Badges
Click Settings
Forum Preferences
Show Participated Displays the participated button next to the navigation tree. Yes No X
Show Signatures Displays member signatures with their posts. Yes X No
Show Avatars Displays member avatars. Yes X No
Forum Theme Displays the available theme of your choice. Original Light Blue
Enable Drafts Saves your posts periodically during creation. Yes X No
Posting Default Sets what editor you default to when creating posts. Preview BBCode
Default BBCode X
Smiles Default [Controls the visibility of smiles across the forum and in your own posts. Your own posts made while this setting is set to disabled will have no smiles visible to you or anyone else.] Sets whether applicable plain text displays as smiles. Enabled X Disabled
Dates and Times Sets how you would prefer to see timestamps. Day Month Year 24 Hour
I have used "X" after the word for example "Enabled X Disabled" = Enabled ticked goto bottom of the page and click {Save Account Settings}, then reload current page in your web browser.
