Post by perkins17 on Oct 2, 2022 18:48:00 GMT -5
I picked up a used Star Diamond TU-12 in working order (basicall a primitive Qt-66) and would love some help getting it back up and running with a new belt. I figure it takes a QT-12 belt, but that's out of stock at Lortone, The Rockshed, and Kingsley north. I also am not sure how to get the belt on, as the shaft that the pulley is on goes throught both sides. Here are some pictures: Bottom: IMG_20221002_163732524 by Perkins17, on Flickr Sides: IMG_20221002_163740794 by Perkins17, on Flickr IMG_20221002_163736333 by Perkins17, on Flickr Top: IMG_20221002_163749002 by Perkins17, on Flickr There doesn't appear to be any clear way to get the shafts to come off, so I'm not too certain on how to get one on. If someone could help me out, I'd really appreciate it. The motor runs great, and the bearings run smooth. Thank you in advance, -Nicholas
JR8675309
Member since August 2019
Post by JR8675309 on Oct 9, 2022 14:39:36 GMT -5
Minnesota lapidary had that belt last I checked. Worst case scenario I have an extra.
Edit: I goofed... on this part, re do: Can you take white cap off end of shaft, remove retaining clips on both ends and slide shaft through one end and then lift it out?
Post by perkins17 on Oct 9, 2022 15:42:43 GMT -5
Minnesota lapidary had that belt last I checked. Worst case scenario I have an extra. Edit: I goofed... on this part, re do: Can you take white cap off end of shaft, remove retaining clips on both ends and slide shaft through one end and then lift it out? Thank you, I appreciate the help. I'll try that once I get home. I wasn't really sure about the end pieces. I heard lortone bought this company out so I'm sure it has similar designs. I can take a 33b apart pretty proficiently in comparison to this.
