vickster
Member since August 2022
Post by vickster on Oct 11, 2022 10:51:37 GMT -5
So I went ahead and purchased this vibratory tumbler (smaller one) and since the noise level has it relegated to the back of my truck inside the shell with a 5 gallon bucket over it, I was wondering if the smaller bowl from a Thumbler’s Vib tumbler would fit this base? I’m thinking it might (?) lessen the noise level. Any thoughts?
Post by pebblesky on Oct 11, 2022 11:28:11 GMT -5
Hmm never thought of that. Wonder if the shape of the base and the length of the shaft would match the Tumbler's mini bowl. If one would have a Tumbler mini bowl handy, that would be interesting to experiment?
vickster
Post by vickster on Oct 11, 2022 12:44:37 GMT -5
The bases look very similar in pictures but hands on is the best.
brybry
Enter your message here...
Member since October 2021
Post by brybry on Oct 11, 2022 13:16:47 GMT -5
The UV mini bowl should work with no issues.
JR8675309
Member since August 2019
Post by JR8675309 on Oct 14, 2022 6:37:54 GMT -5
To dampen noise I put two bubble mailers between lid and top of base, it's surprising how much noise that reduces! I find the 5 gallon bucked intriguing... can you insulate the inside while still leaving room for heat to escape?
muaddib
Member since July 2022
Post by muaddib on Oct 19, 2022 5:54:44 GMT -5
The instructions I saw on this YouTube video from Ryman/Raytech tell me to fasten the lid on very tight until the rubber bulges (I do this with BOTH rubber nuts) if you don't do this the noise increases significantly.
As the right honourable poster above me has alluded to, the lid can cause the noise.
vickster
Post by vickster on Oct 19, 2022 12:10:35 GMT -5
Well, I took the plunge and am running a Thumbler’s mini bowl in my Ray-Tech 5. One thing I noticed right away was the tumbling action is amazingly better. Probably due to bowl shape (?). I have one concern, I had to add some extra media so I’m hoping the extra weight doesn’t cause issues. If all runs well I think I get another bowl and run those instead of the Ray-Tech bowls. And, yes, I realize I just voided their warranty.
Post by pebblesky on Oct 19, 2022 12:56:37 GMT -5
Well, I took the plunge and am running a Thumbler’s mini bowl in my Ray-Tech 5. One thing I noticed right away was the tumbling action is amazingly better. Probably due to bowl shape (?). I have one concern, I had to add some extra media so I’m hoping the extra weight doesn’t cause issues. If all runs well I think I get another bowl and run those instead of the Ray-Tech bowls. And, yes, I realize I just voided their warranty. Really look forward to your further updates!
brybry
Post by brybry on Oct 19, 2022 14:29:41 GMT -5
Well, I took the plunge and am running a Thumbler’s mini bowl in my Ray-Tech 5. One thing I noticed right away was the tumbling action is amazingly better. Probably due to bowl shape (?). I have one concern, I had to add some extra media so I’m hoping the extra weight doesn’t cause issues. If all runs well I think I get another bowl and run those instead of the Ray-Tech bowls. And, yes, I realize I just voided their warranty. Round bottom compared to a flat bottom. Bet it's quieter too.
bawcustoms
Member since June 2022
Post by bawcustoms on Oct 25, 2022 9:54:46 GMT -5
I've been using the UV-10 mini bowls on my TV-5 for about 6 months now. The action is definitely a lot better. I'd actually say the action is a little too good. I make sure the bowl is stuffed full and add some extra borax to help slow it down or it tends to bruise the rocks a bit. I haven't tried adding sugar to slow it down yet but I may try that soon. Overall I'd say the mini bowl is a big upgrade from the raytech bowls if you don't mind spending the extra money.
vickster
Post by vickster on Oct 25, 2022 13:40:09 GMT -5
I wanted to update on my experiment of using a Thumbler’s UV-10 mini bowl on a smaller Ray-Tech base. It is working great. The shine I got on my last batch was amazing. The tumbling action is fine and the Ray-Tech is having no issues with the Thumbler’s bowl. I have a working vibrating tumbler!! I ordered another bowl (Kingsley North) to use for polish only. So this an option for others wanting to get into vibratory tumbling since the other companies vib tumblers are at present out of stock.
Post by pebblesky on Oct 25, 2022 15:29:06 GMT -5
I wanted to update on my experiment of using a Thumbler’s UV-10 mini bowl on a smaller Ray-Tech base. It is working great. The shine I got on my last batch was amazing. The tumbling action is fine and the Ray-Tech is having no issues with the Thumbler’s bowl. I have a working vibrating tumbler!! I ordered another bowl (Kingsley North) to use for polish only. So this an option for others wanting to get into vibratory tumbling since the other companies vib tumblers are at present out of stock. Please share with us some pictures of your polished batches!
Post by angelseakr1957 on Sept 19, 2024 8:41:02 GMT -5
Hey Vickster! I wanted to let you know I copied your experiment, and I'm extremely pleased. I did have trouble with one of the motors going but I think it's because I put the larger UV Barrel on the TV 5 Base. Ship me out a new one free of charge. I would love to hear any new tips you have regarding the modified tv/uv tumbler!
