winterwinds
Member since October 2022
Post by winterwinds on Oct 20, 2022 19:06:55 GMT -5
Anyone with a recently purchased HF tumbler that might be kind enough to measure and post the height, width and depth? It's not in the manual they have online. I live in a small condo and would like to add barrels if they'll fit in my "tumbling cabinet". Thanks!
Post by liveoak on Oct 22, 2022 6:33:46 GMT -5
I'll bring one of mine in the house today & measure it up for you.
Patty
Post by liveoak on Oct 22, 2022 8:26:48 GMT -5
HF 3 lb Barrel size
Diameter 4 3/8"
Height of drum 4 3/4" Height at center nut of drum- 5 1/2"
Patty
winterwinds
Post by winterwinds on Oct 23, 2022 13:45:44 GMT -5
Thanks, that was kind of you!
rockfly
Post by rockfly on Oct 29, 2022 15:27:18 GMT -5
I have one of the of the double barrel HF tumblers. It is 15" length, 6 1/2" wide and 7" height. The barrels are very small on the single one so I chose to go with the double barrel and glad I did. If you have the room I would go this route. We did have issues right away with belts breaking. We found that you cannot fill the barrels with as much rock as the owners manual states and my hubby found a burr on one of the shafts that was also cutting into the belt. One he smoothed the burr off it has been working away with no problem. Hope this helps. When HF had a coupon I could also buy the double barrel for less than the single barrel. Good luck!
