Post by therockapprentice on Nov 5, 2022 15:07:15 GMT -5
You use what you have. A dremel with a diamond bit will remove lots of the opaque oxidized material and a finer one will clean grooves. I've even tried cutting leather disks that can be mounted on a dremel to carry various grits using Vaseline as a carrier. As pointed out pea gravel should work in almost any vibe. The object is to create some progress and occasionally something of beauty in your view. Thanks. I like your idea of a dremel w a diamond bit. I think that may be my best option if pea gravel doesn’t yield enough results. Thanks again.
