aeronautee
Member since September 2011
Post by aeronautee on Nov 10, 2022 20:18:41 GMT -5
I want to start cabbing and I'm wondering how thick I should cut the slabs. Thanks!
Post by vegasjames on Nov 10, 2022 20:20:48 GMT -5
Going to depend on the cab. For larger cabs or high doming I cut my slabs thicker.
realrockhound
Chucking leaverite at tweekers
Member since June 2020
Post by realrockhound on Nov 10, 2022 20:25:36 GMT -5
1/4 inch is standard.
Post by jasoninsd on Nov 10, 2022 21:16:36 GMT -5
Realrockhound is correct with the "standard". Some people will cut certain material thinner...if it's valuable material, thinner slabs mean more cuts out of the rough. I've cabbed pieces where the slab was only 1/8" thick. It isn't fun...and the dome is nearly flat...but it CAN be done. I wouldn't cut a slab thicker than 3/8" thick...well...not purposely! LOL
Post by rmf on Nov 11, 2022 3:16:45 GMT -5
There are a lot that do 1/4" but I always liked 5/16" which is 5 turns on the feed crank. Depending on the material and hardness.
