realrockhound
Chucking leaverite at tweekers
Member since June 2020
Post by realrockhound on Nov 15, 2022 15:34:30 GMT -5
What oil do you guys use and where do you get it from? It’s time for me to oil my vacuum pump.
Post by rockjunquie on Nov 15, 2022 16:26:56 GMT -5
What oil do you guys use and where do you get it from? It’s time for me to oil my vacuum pump. Pretty sure DP says WD30. That's what I use.
realrockhound
Post by realrockhound on Nov 15, 2022 16:36:20 GMT -5
What oil do you guys use and where do you get it from? It’s time for me to oil my vacuum pump. Pretty sure DP says WD30. That's what I use. WD30 or WD40? I’ve never heard of WD30
Post by rockjunquie on Nov 15, 2022 16:39:36 GMT -5
Pretty sure DP says WD30. That's what I use. WD30 or WD40? I’ve never heard of WD30 Just looked at my manual. It says
To oil the leathers, remove the left hand hood. The pump will then be exposed. Remove the middle screw (see picture) that is painted red. Place one drop of 30 weight motor oil in the hole and replace the screw. This hole oils the leathers, and any excess oil will eventually come out the air outlet tubing and into the water pan.
Post by rockjunquie on Nov 15, 2022 16:41:12 GMT -5
Pretty sure DP says WD30. That's what I use. WD30 or WD40? I’ve never heard of WD30 I bought a quart just for Gene.
realrockhound
Post by realrockhound on Nov 15, 2022 17:10:29 GMT -5
Perfect thank you. I don’t have the manual for mine, so this is very helpful. I don’t know why, but I just assumed there was a special type to use. Thank you 😊
Post by rockjunquie on Nov 15, 2022 17:42:12 GMT -5
Perfect thank you. I don’t have the manual for mine, so this is very helpful. I don’t know why, but I just assumed there was a special type to use. Thank you 😊 You're welcome. I think you can download a manual from their site- you useta could.
realrockhound
Post by realrockhound on Nov 15, 2022 17:52:22 GMT -5
Perfect thank you. I don’t have the manual for mine, so this is very helpful. I don’t know why, but I just assumed there was a special type to use. Thank you 😊 You're welcome. I think you can download a manual from their site- you useta could. I’ll try that. Thank you
Post by parfive on Nov 15, 2022 17:59:25 GMT -5
Fwiw, Tela, WD is not motor oil, 30 or 40 or otherwise.
Post by rockjunquie on Nov 15, 2022 18:17:23 GMT -5
Fwiw, Tela, WD is not motor oil, 30 or 40 or otherwise. Crap! You're right. My bad. I don't know what I was thinking. BUT, at least I quoted the manual.
Post by hummingbirdstones2 on Nov 15, 2022 18:36:20 GMT -5
Yep, it's always been straight 30 weight according to Don at DP.
I cheat and drop some 20W into the pump for the leathers now and then, but only use 30W in the lower port.
Post by Rockoonz on Nov 16, 2022 11:28:03 GMT -5
Vince beat me to it. There are 2 places to oil on a genie, both are important.
