Post by rockjunquie on Nov 18, 2022 12:22:22 GMT -5
I got that eBay tumbler. It looks new. But, it's missing a foot. I looked everywhere for one and couldn't find one. Do y'all have any ideas for DIY or buy?
Post by Rockoonz on Nov 18, 2022 12:30:32 GMT -5
I would call Kingsley and the rock shed first, Lortone might answer but last I heard they were only talking to commercial customers because they are so far behind. Also put up a pic, they are probably hardware store stuff and I'm pretty good at finding stuff like that.
Post by rockjunquie on Nov 18, 2022 12:45:07 GMT -5
Thanks, Lee Rockoonz ! I'm thinking they are stick on. I checked those websites, but I guess I can call, too. If I have to, I could just get any set of stick on feet, I guess.
Post by Starguy on Nov 18, 2022 12:59:43 GMT -5
They’re just stick on but you need to make sure there is no oil on the base before you try to stick them on. A door shim under the corner of the base will work in a pinch.
Post by rockjunquie on Nov 18, 2022 13:03:43 GMT -5
Just found some feet on Amazon.
Sorry, guess I should have looked harder before I asked, but I didn't realize they were just stick ons.
Post by aDave on Nov 18, 2022 13:39:01 GMT -5
If you don't want to wait and you have a Home Depot near you, you can find similar there, as well. Lowe's would also probably work. I keep a bunch of those on hand for different needs...tumblers included.
geoff59
Member since October 2022
Post by geoff59 on Nov 18, 2022 14:55:44 GMT -5
A good hardware store should have a set of 4, or Wallyworld or similar. I would consider removing the remaining 3 and sticking a new matching set of 4 on it.
inbtb
Member since May 2016
Post by inbtb on Nov 18, 2022 15:41:16 GMT -5
They have feet? Actually those come off so easy I don't even mess with replacing them. Run without them just fine.
Post by Rockoonz on Nov 18, 2022 16:20:25 GMT -5
Yep, a true value HW should have feet like that (non slip) in sheets of 4 or more on backing paper in the drawers on the hardware aisle. Alcohol or acetone on a paper towel should prep it fine. Your link just took me to my Amazon list of stuff I've looked at.
