dirtsifter
Co to za kamyczek?
Member since September 2022
Post by dirtsifter on Nov 19, 2022 21:59:34 GMT -5
Kingsley North notification: Lot o tumbler is back in stock.
Just ordered one. Yippee!
My bride said Merry Christmas, order it!
nursetumbler
Member since February 2022
Post by nursetumbler on Nov 20, 2022 3:37:52 GMT -5
Kingsley North notification: Lot o tumbler is back in stock. Just ordered one. Yippee! My bride said Merry Christmas, order it! Congratulations dirtsifter
Post by Son Of Beach on Nov 20, 2022 8:07:59 GMT -5
Kingsley North notification: Lot o tumbler is back in stock. Just ordered one. Yippee! My bride said Merry Christmas, order it! Congrats Dirtsifter, it's a great little unit.
I just want to give you a heads up on some of the "issues" if they do arise
Some people have found that the spring placement is a little off causing less than ideal vibration. I've been lucky enough where I haven't had to make an adjustment.
You might run into overly thick slurries. Some if it is trial and error, but I recommend a half squirt of dishsoap in your post coarse stage, that seems to be the step were it can bog down.
Once you get your unit, you'll see the fans need to be lined up in a certain way and if they don't the unit becomes MUCH noisier and you'll want to fix that ASAP as it's not vibing at the right rhythm. Some have glued their fans to right positions so they don't have to correct the positioning going forward.
The lids can also jump off without something holding it on. Myself and others use some kind of rubber band or bungees to keep it in place. One member found a spaghetti sauce lid that fit exactly!'
Outside of that ask any question you have and make sure to show PICTURES so we can oogle your work
dirtsifter
Co to za kamyczek?
Post by dirtsifter on Nov 20, 2022 10:11:29 GMT -5
Thank you so much!
dirtsifter
Co to za kamyczek?
Post by dirtsifter on Nov 21, 2022 5:07:19 GMT -5
Sadly, they are now out of stock. That was fast
mgroothuis
Member since November 2022
Post by mgroothuis on Nov 21, 2022 16:07:13 GMT -5
I was able to get one today as well. I've been seriously looking for a few weeks. I got the notification from Kingsley North and ordered within a couple minutes. Either it was the only one, or 4 minutes later they were all sold out again. It's crazy.
