vance71975
Member since September 2022
Post by vance71975 on Nov 25, 2022 19:46:38 GMT -5
I am looking for a Classifer pan for sifting rocks from dirt, but I want the mesh in the bottom to be 1 inch squares to let any rock smaller than 1 inch fall through but for the life of me I can not find one, Anyone have any Sources for classifer sifting pans with larger mesh? I would even consider a 2 inch mesh, I am looking for something to sift on the fly when im out rockhounding so i dont have to pull out a ruler and measure each stone 1 by 1 lol. But I dont really want anything smaller than 1 inch for tumbling( I have plenty of smalls, like 40lbs of smalls). So far the biggest I can find is 7/8. I really dont want to go less than 1 inch.
Post by jasoninsd on Nov 25, 2022 20:10:43 GMT -5
...not really answering your question...but why not make your own out of some 2x2s and some hog wire?
vance71975
Post by vance71975 on Nov 25, 2022 20:53:00 GMT -5
...not really answering your question...but why not make your own out of some 2x2s and some hog wire? Well, I am lazy mostly and I dont much like building things lol. But I am considering doing an all wood box with a 1in hole drill bit and some sheets of plywood I have. But I would much rather buy it premade if I can.
Post by jasoninsd on Nov 25, 2022 21:03:17 GMT -5
...not really answering your question...but why not make your own out of some 2x2s and some hog wire? Well, I am lazy mostly and I dont much like building things lol. But I am considering doing an all wood box with a 1in hole drill bit and some sheets of plywood I have. But I would much rather buy it premade if I can. I get it! LOL I think you'll have a difficult time trying to find one that's premade with holes that big. If you make it out of all wood, the weight is going to be pretty hefty...
vance71975
Post by vance71975 on Nov 25, 2022 21:47:10 GMT -5
Well, I am lazy mostly and I dont much like building things lol. But I am considering doing an all wood box with a 1in hole drill bit and some sheets of plywood I have. But I would much rather buy it premade if I can. I get it! LOL I think you'll have a difficult time trying to find one that's premade with holes that big. If you make it out of all wood, the weight is going to be pretty hefty... Its fairly thin plywood, maybe an inch thick and I dont plan on making it very big, small enough to fit in a backpack/ruck sack. I am getting a 100L rucksack/Backpack, so I may make it 12x8x4 inchs total. Might add 3 or 4lbs to my sack, which, will still be lighter fully loaded than what I humped around in the army lol.
Post by jasoninsd on Nov 25, 2022 22:20:48 GMT -5
I get it! LOL I think you'll have a difficult time trying to find one that's premade with holes that big. If you make it out of all wood, the weight is going to be pretty hefty... Its fairly thin plywood, maybe an inch thick and I dont plan on making it very big, small enough to fit in a backpack/ruck sack. I am getting a 100L rucksack/Backpack, so I may make it 12x8x4 inchs total. Might add 3 or 4lbs to my sack, which, will still be lighter fully loaded that what I humped around in the army lol. I was picturing something 2'x4' for some reason! LOL
vance71975
Post by vance71975 on Nov 26, 2022 1:40:42 GMT -5
jasoninsd something like this only with a drilled wood bottom instead of screen and likely smaller lol
Post by Starguy on Nov 26, 2022 15:14:23 GMT -5
vance71975
Post by vance71975 on Nov 26, 2022 15:29:55 GMT -5
ya that is a bit out of my price range, but thank you, if money situation changes i know where to go!
Post by Pat on Nov 26, 2022 16:23:38 GMT -5
Seems to me, if wet, the drilled wood would swell.
vance71975
Post by vance71975 on Nov 27, 2022 5:51:28 GMT -5
Seems to me, if wet, the drilled wood would swell. It likely would yes. I do however plan to waterseal and varnish the wood, if I decide to build one to prevent this issue.
Post by victor1941 on Nov 27, 2022 11:37:39 GMT -5
Try collapsible plastic containers and size the bottom holes to 1".
Post by rmf on Nov 27, 2022 14:16:58 GMT -5
What I have used for years is a 4 gal milk Carton that has 1" square holes in the bottom. Many do not have 1" holes but I had a couple and that worked. I wrapped the sides in duct tape to keep the side holes from leaking.
vance71975
Post by vance71975 on Nov 27, 2022 14:27:25 GMT -5
What I have used for years is a 4 gal milk Carton that has 1" square holes in the bottom. Many do not have 1" holes but I had a couple and that worked. I wrapped the sides in duct tape to keep the side holes from leaking. that is brilliant! I would have to cut it off so that it fits in the ruck sack but pure genius man!
vance71975
Post by vance71975 on Nov 27, 2022 15:18:29 GMT -5
What I have used for years is a 4 gal milk Carton that has 1" square holes in the bottom. Many do not have 1" holes but I had a couple and that worked. I wrapped the sides in duct tape to keep the side holes from leaking. Just so happens there are a ton of old milk carton carriers at my house and wouldnt you know it, the bottom squares are just under 1 1/2 inch, Thank you again man I got my sifter free just need to cut it off so that it will fit in the ruck sack!
vance71975
Post by vance71975 on Nov 28, 2022 12:16:48 GMT -5
rmf so here it is, thanks again for the brilliant Idea!!
