QuailRiver
Post by QuailRiver on Dec 29, 2022 15:11:04 GMT -5
Let the oil sit without turning the saw on for a day or two to let as much sludge settle as possible. Pump off the top layer of cleaner oil into a bucket without disturbing the sludge. Then pump out as much of the dirty sludge/oil as will pass through the pump and filter it through a brown paper bag. Then dump enough cat litter into the reservoir to soak up the thicker rock sludge oil and scoop out and throw away the dirty thick dirty litter/sludge. Then wipe out and clean up the inside of the saw reservoir with a terrycloth rag. And your ready to add clean oil and start slabbing again!
AzRockGeek
Member since September 2016
Post by AzRockGeek on Dec 29, 2022 16:19:30 GMT -5
If the oil on top of the sludge looks clean, just scrape out the sludge on the bottom with a putty knife.
Some people use old shop vacs to suck it out, I have never tried it.
Good luck.
Post by parfive on Dec 29, 2022 18:11:26 GMT -5
If there’s still no sign of a drain after you’ve cleaned it out and you’d like to simplify the next cleanout, install a drain before you refill.
Post by jasoninsd on Dec 29, 2022 21:23:01 GMT -5
Have you considered hiring a day laborer to do it? *Just giving you another option! LOL
Post by mohs on Dec 29, 2022 21:25:08 GMT -5
I got hair brain idea Not going to help w/ the presnt situation And it may already have been manufactured
Have they made a saw with slant bottom w/ a drain plug? Well not to slanted cause you want the blade to stay bathed
Perhaps with attachable bag system to filter the oil?
I used to operate a Vollmer CNC Saw Sharpener It had a large pullout wheeled drawer that held the pumped flood coolant Think it was 10 gallon. Lots.
Emptying that tub was a problem. With all that fine carbide gunk in it.
Came up with the brilliant idea to drill a drain plug in the bottom of the drawer , We even made a ramp to push the drawer on up on for easier disposal into 1/2 drum with a filter. We didn’t reuse the coolant tho
Anyway an old idea. Wonder if some one makes that setup?
If not= credit mohs w/ the royalties Or at least a gneiss rock
I think Vollemer as even incorporated the idea Butte do they recognize the original mohs ? No
mostly
Post by catmandewe on Dec 30, 2022 0:08:21 GMT -5
Post by mohs on Dec 30, 2022 13:25:58 GMT -5
As I venture deeper into the cut
wonder if anyone as ever tried flood coolant idea?
know it would be tricky compared to the saw blade always bathed in oil
Yet a flood coolants system would greatly reduce the clean up mess
the vid towards the end show the Vollmer flood coolant system
