Post by jasoninsd on Jan 1, 2023 23:51:24 GMT -5
Gorgeous!! - What did you use between the two slabs? Is it just epoxy showing as that "spacer", or is this a "triplet"? - Do you always do the corners first like that? I do the sides first, then corners. Just wondering if you find it easier for some reason...
Post by jasoninsd on Jan 2, 2023 0:36:25 GMT -5
Gorgeous!! - What did you use between the two slabs? Is it just epoxy showing as that "spacer", or is this a "triplet"? - Do you always do the corners first like that? I do the sides first, then corners. Just wondering if you find it easier for some reason... Thanks! It’a a single slab, those are a couple lines drawn on the side to define one side from the other. the missing corner was just part of the preform before I started, just ended up being there due to the section of the rock I chose to cab. I didn’t grind that corner first, but it was a limiting factor in the dome shape on that side. Dang! You had me fooled all the way around! LOL
adrian65
Member since February 2007
Post by adrian65 on Jan 2, 2023 1:04:04 GMT -5
Beautiful! Square cabs are not easy to do, the slightest imperfection is so visible.
I like the pillow look of this cab.
Adrian
