Post by Drummond Island Rocks on Jan 24, 2023 15:28:16 GMT -5
This was my first batch that was completed in the altered lot-o. No difference at all compared to the original. Same motion, Same temperature at the motor and barrel, same sound, same end result. Easy agates may have been a bad example. Really should throw some obsidian at it. All Bahia and Carnelian agates 1 2 3 4 5 6 7 8 9 10 11 12 Fins removed and holes laid out for mounting Mounted with spacers to prevent heat transfer Final locations and amount of weight per side Thanks for looking Chuck
Post by rockjunquie on Jan 24, 2023 16:29:47 GMT -5
This was my first batch that was completed in the altered lot-o. No difference at all compared to the original. Same motion, Same temperature at the motor and barrel, same sound, same end result. Easy agates may have been a bad example. Really should throw some obsidian at it. All Bahia and Carnelian agates 1 2 3 4 5 6 7 8 9 10 11 12 Fins removed and holes laid out for mounting Mounted with spacers to prevent heat transfer Final locations and amount of weight per side Thanks for looking Chuck I don't see a difference- they look great, as always.
hoolligan1938
Member since January 2022
Post by hoolligan1938 on Jan 24, 2023 18:10:17 GMT -5
Beautiful, Chuck! I thank you for the photos of the modifications and for all your information that you have shared with us.
Jim
Post by Jugglerguy on Feb 7, 2023 21:35:07 GMT -5
That's good news, Chuck. Thanks for doing this for the RTH community.
dirtsifter
Co to za kamyczek?
Member since September 2022
Post by dirtsifter on Feb 7, 2023 23:09:19 GMT -5
Great looking rocks!
Post by aDave on Feb 7, 2023 23:23:46 GMT -5
Nice, Chuck. Was there a specific template you used for figuring out exact mounting location, supplies, and the actual "how to?" I know there is a thread floating around...is that what you used? I guess I should look for it and bookmark it.
Post by Drummond Island Rocks on Feb 8, 2023 8:29:38 GMT -5
Nice, Chuck. Was there a specific template you used for figuring out exact mounting location, supplies, and the actual "how to?" I know there is a thread floating around...is that what you used? I guess I should look for it and bookmark it. Honestly it is so easy a tutorial is not really needed. Cut off the two existing brackets. Hold the motor against the back and mark the spots for 4 holes. As far as height of the motor on the back my side shot photo does a good job of showing that. I think I mounted it a little lower then the sharpie marks in that photo to make it easier to access the nuts. 5/16 button head bolts with 3/8 nuts used as spacers between the motor and back of the lot-o. I will replace the standard 5/16 nuts with locknuts next time I get to the hardware store. With a good cutoff tool this whole thing is only a 20 minute job. Edit: The cord does not come with a plug end and is "international standard colors" so use this to wire a plug end to it. www.homedepot.com/p/Leviton-15-Amp-125-Volt-3-Wire-Plug-Orange-R51-515PV-0OR/205165505Chuck
Post by Rockoonz on Feb 8, 2023 8:36:33 GMT -5
Nice. We got a barrel (tub?) with no base at the estate we bought yesterday, since we now have 3 barrels and one base maybe I should try to duplicate one. Who sells the motor?
Post by Drummond Island Rocks on Feb 8, 2023 9:18:34 GMT -5
Nice. We got a barrel (tub?) with no base at the estate we bought yesterday, since we now have 3 barrels and one base maybe I should try to duplicate one. Who sells the motor? Got mine on amazon. I think about $40 Chuck
Post by aDave on Feb 8, 2023 11:16:14 GMT -5
Honestly it is so easy a tutorial is not really needed. Cut off the two existing brackets. Hold the motor against the back and mark the spots for 4 holes. As far as height of the motor on the back my side shot photo does a good job of showing that. I think I mounted it a little lower then the sharpie marks in that photo to make it easier to access the nuts. 5/16 button head bolts with 3/8 nuts used as spacers between the motor and back of the lot-o. I will replace the standard 5/16 nuts with locknuts next time I get to the hardware store. With a good cutoff tool this whole thing is only a 20 minute job. Edit: The cord does not come with a plug end and is "international standard colors" so use this to wire a plug end to it. www.homedepot.com/p/Leviton-15-Amp-125-Volt-3-Wire-Plug-Orange-R51-515PV-0OR/205165505Chuck Nice. Very helpful and clear. Thanks very much.
jawsjr
Member since June 2019
Post by jawsjr on Mar 15, 2023 13:00:09 GMT -5
There is good information here. Hanging on to it just incase I have a motor that dies.
rocknewb101
Member since October 2022
Post by rocknewb101 on Mar 15, 2023 15:04:40 GMT -5
Beautiful rocks!! Such shine to them. Also, thanks for sharing this alteration for the lot-o motor. Company honored my warranty, but if I run into that again there are several great tips here to replacing them cheaply.
ClassicRock
Member since December 2022
Post by ClassicRock on Mar 31, 2023 22:08:34 GMT -5
Everything looks great and those agates are fantastic! Thanks for sharing all of the info @drummond Island Rocks!
