hhhrocks
Member since January 2023
Post by hhhrocks on Jan 30, 2023 15:45:06 GMT -5
Looking for how to straighten warped 10 inch diamond cutting blades. Any help is welcome, hate to buy new ones.
Post by mohs on Jan 30, 2023 16:10:28 GMT -5
Straitening a blade is tricky question Butte hammering is the usual answer
Why is warped ? Did it get hot . If you as a heat blister? Then hammering might be the only possible solution
Have you put checked blade run out W/ dial indicator ? .
If the run out is slight you might improve it by tweaking the blade by hand perhaps a pair of pliers while its on saw arbor
You can also use a stabilized pencil or any stiff pointer leveled on the body of the blade and spin the blade by hand on the arbor
Find the high spot or where the wobble is/ Then try to tweak it by hand
Other may have even better ideas
Welcome to RTH
Ed
Post by perkins17 on Jan 30, 2023 18:20:05 GMT -5
Put it on the flat side of a cinderblock, and spin occasionally while lightly tapping the blade flat with a rubber mallet. I've had pretty good success on this with my 7 inch tile/rock blade, although thr arbor of the saw has a slight wobble.
