Post by hummingbirdstones on Mar 17, 2023 12:43:51 GMT -5
Well, Hell. I'm pissed. My oven was supposed to be here today. I was all ready to dry the slabs and test the temperature. My wrap teaching date was rescheduled, so now I have plenty of time to stabilize. NOT!!! No oven. It won't be here til Tues now. I ordered it on the 7th from Amazon Prime. What gives??
AND, the Art Resin didn't harden properly. I know I mixed it right right. I measured it.
Boo! That sucks! I'm sorry your oven got delayed. Prime doesn't seem to make a flippin' bit of difference on when your order arrives anymore. It's almost a scam now to pay for Prime and not have your order in 2 days.
Post by liveoak on Mar 17, 2023 13:04:33 GMT -5
Sorry about the oven Tela. No rocks will be heated before their time Why is it that some projects take on a life of their own ??
My epoxy guy here, suggested to clean your uncured stone with acetone and start over .
Patty
Post by jasoninsd on Mar 17, 2023 16:49:23 GMT -5
Boo! When I did it, mine took a bit to completely harden... *There's an "old guy" joke in there...but I'm gonna let it go! LOL
Post by rockjunquie on Mar 21, 2023 16:05:34 GMT -5
WE HAVE OVEN!!!!! And, the water is almost perfectly clear. There were a few bubbles when I emptied it. I will be drying them in the big oven and testing the temps. (Lots of dust in the water- not oil.)
Sadly, Sat and Sun are booked. Sun MAY be a go, but I'm not sure ATM. Maybe I can get it done before then. I have a lot of appts, though. OMG! This has turned into quite the adventure!
Post by jasoninsd on Mar 21, 2023 16:09:05 GMT -5
Those look great in the bucket of water...kind of like opals look in water filled glass jars. If you just kept these in the water bucket and occasionally shifted them around, you might not even need that oven! LOL *Glad to hear you finally got the EZ Bake!!
Post by hummingbirdstones on Mar 21, 2023 16:41:23 GMT -5
YAY! I'm so excited to see how this works.
Post by rockjunquie on Mar 21, 2023 16:51:10 GMT -5
YAY! I'm so excited to see how this works. ME, TOO! After all this - IT BETTER WORK! LOL!
Post by rockjunquie on Mar 21, 2023 16:51:57 GMT -5
Those look great in the bucket of water...kind of like opals look in water filled glass jars. If you just kept these in the water bucket and occasionally shifted them around, you might not even need that oven! LOL *Glad to hear you finally got the EZ Bake!! This is a pretty big EZ bake. (It does have a bulb in it. )
khara
Member since September 2022
Post by khara on Mar 21, 2023 21:45:39 GMT -5
Those are some really pretty slabs. 👍👍
Post by liveoak on Mar 22, 2023 6:15:21 GMT -5
Glad to hear progress - looking forward to seeing more glossy photos. Patty
rockbrain
Member since January 2022
Post by rockbrain on Mar 23, 2023 15:07:14 GMT -5
What's the red, yellow, brown right of center with the druzy in the middle?
Post by rockjunquie on Mar 23, 2023 15:15:25 GMT -5
What's the red, yellow, brown right of center with the druzy in the middle? It's not druzy, it's just the picture. It's a very special MHPJ.
Post by jasoninsd on Mar 23, 2023 15:21:27 GMT -5
What's the red, yellow, brown right of center with the druzy in the middle? I'm betting Morgan Hill Poppy Goodness! LOL EDIT - I took too long to write my post...Tela posted before I did! LOL
Post by rockjunquie on Mar 23, 2023 15:48:16 GMT -5
What's the red, yellow, brown right of center with the druzy in the middle? I'm betting Morgan Hill Poppy Goodness! LOL EDIT - I took too long to write my post...Tela posted before I did! LOL You would have won that bet!
rockbrain
Post by rockbrain on Mar 23, 2023 21:35:09 GMT -5
MHPJ was my first inclination but the more I looked at it the less convinced I was. Amazing piece. Have you decided what you're going to do with it?
Post by rockjunquie on Mar 24, 2023 8:18:24 GMT -5
MHPJ was my first inclination but the more I looked at it the less convinced I was. Amazing piece. Have you decided what you're going to do with it? I hope to cab it. The other side is better. The "druzy" is quartz.
Tracie
Post by Tracie on Mar 26, 2023 23:56:42 GMT -5
What is the best way and the easiest way to stabilize slabs if you do not have a vacuum?
rockbrain
Post by rockbrain on Mar 27, 2023 14:19:01 GMT -5
What is the best way and the easiest way to stabilize slabs if you do not have a vacuum? Check this out.
Tracie
Post by Tracie on Mar 27, 2023 18:35:11 GMT -5
What is the best way and the easiest way to stabilize slabs if you do not have a vacuum? Check this out.Thank you!
yurii
Member since March 2023
Post by yurii on Apr 3, 2023 1:14:37 GMT -5
Hello . A very interesting topic. I hope everything worked out for you as planned. I once also experimented with a vacuum. I have a powerful vacuum pump for jewelry purposes. He does a great job, but not always. I also tried to impregnate the plates, but the cracks are very small. In this case, the impregnating liquid does not get into them. If you sawed the plates with oil, then it remains in the cracks and can greatly interfere. In order to somehow protect the rock from oil, I recommend putting the sample in water for a long time before sawing. Especially porous materials. And before making the plates, wipe thoroughly. After sawing, immediately boil in water with the addition of ordinary baking soda. And for impregnation I used a solution of epoxy resin in acetone - 50/50. You can experiment with many resins and stabilizers. But from personal experience, I can say that it is best to impregnate an already formed cabochon, which has already been shaped. In this case, it is much lighter and better impregnated. The easiest way to create a vacuum is with a medical syringe. They come in different sizes. You need to cut off its end, and we get a kind of vacuum chamber. Press it (when the impregnated sample is inside) to the rubber glued on a flat surface, and pull it towards you. Sometimes, when I'm in a hurry, I just press it to my hand)))) To improve the effect, you need to create a vacuum several times, this applies to both the syringe and the vacuum pump. In addition , there are manual vacuum pumps . When I worked as a geologist, we used these to take samples from the soil. This pump is very similar to a manual ( automobile ) pump , but slightly larger . But the old car pump can also be converted into a vacuum one - turn the cuffs in the opposite direction and put the valve at the inlet. A vacuum chamber can be made from an ordinary pan by soldering or gluing a fitting onto silicone (either into the pan itself or into a flat surface to which it is pressed. But you also need to put an ordinary ball valve to release the vacuum. It is better to take soft rubber for the substrate (there is a special vacuum rubber, we have it white) It needs to be glued on a flat, sufficiently strong surface... As for heating, I use an ordinary hair dryer (my wife does not mind)))))), but you can also buy a building hair dryer. Epoxy resin is not capricious in terms of temperature, although it is clear that in your case it is necessary to adhere to the temperature regime.
