Post by rockjunquie on Mar 15, 2023 10:23:00 GMT -5
OK, the azurite looks good. SOME of the chrysocolla looks ok- others are a strange shade of blue green. We'll see after the fresh water soak and oven. I have high hopes at the moment.
The pic doesn't show the questionable ones.
Post by hummingbirdstones on Mar 15, 2023 13:01:35 GMT -5
They look good. If the questionable ones still look questionable after the water soak, I wouldn't worry to much. Most likely it will be surface only. You can test to see by just running a spot of one under Gene.
Post by rockjunquie on Mar 15, 2023 13:16:12 GMT -5
They look good. If the questionable ones still look questionable after the water soak, I wouldn't worry to much. Most likely it will be surface only. You can test to see by just running a spot of one under Gene. Thanks for the vote of confidence. Yeah, I was thinking it would probably grind off, but there is a risk the color gets messed up all the way through. It was the softest stuff. But, I feel pretty good with it right now.
rockbrain
Member since January 2022
Post by rockbrain on Mar 15, 2023 19:50:14 GMT -5
I've used Simple Green undilutede on my concrete driveway and it didn't turn the porous concrete green.
Post by liveoak on Mar 16, 2023 6:25:59 GMT -5
I'm afraid to suggest anything - but a vinegar soak or a bleach soak came to mind to try But I'm NOT suggesting it & I deny all responsibility. Patty
Post by rockjunquie on Mar 16, 2023 6:47:58 GMT -5
The fresh water is turning a dirty pale green, so some of it is coming off. I'll get a pic later. I have hope.
Post by rockjunquie on Mar 16, 2023 9:06:13 GMT -5
This is in the shadows a little, but you can see the water is far from clear anymore. I'm gonna pull them out and add fresh water.
Post by liveoak on Mar 16, 2023 9:09:08 GMT -5
I wonder if warm to hot water would make it work faster ?
Patty
Post by rockjunquie on Mar 16, 2023 9:32:57 GMT -5
I wonder if warm to hot water would make it work faster ? Patty I started out with pretty warm water and then it cooled to room temp. I just filled it again with clean water. I examined some of the off stones and they look better. Yay!
Post by liveoak on Mar 16, 2023 9:47:15 GMT -5
I think I might keep doing it (and changing the water) until the water stays absolutely clear.
Patty
Post by rockjunquie on Mar 16, 2023 10:01:31 GMT -5
I think I might keep doing it (and changing the water) until the water stays absolutely clear. Patty Yeah, we'll see. I got my eye on it.
Post by Rockoonz on Mar 16, 2023 10:23:22 GMT -5
I touch of chlorine bleach in the rinse is what I use with light colored porous materials after cutting in old discolored saw oil, when I forget to save them for fresh oil. Works pretty good.
Post by rockjunquie on Mar 16, 2023 11:39:01 GMT -5
I'm getting tired of waiting, so I decided to try some art resin on that really desperate piece of pulsite. I doubt it can be saved. It's on a coffee warmer under a light bulb. In a couple hours, I'll flip it over and do it again. It ran straight through that big crack on the bottom. I may be able to save a small cab out of it. This was just for grins and giggles. I have no high expectations.
Post by jasoninsd on Mar 16, 2023 12:00:21 GMT -5
Not "poo-poo'ing" what you've done...just thinking out loud. I can see the AR holding the slab together in order to cut preforms...but I'll be curious to see if the AR has any effect other than that. In my head, I imagine this material has space between the "parts" which is causing it to be brittle. I would think this particular piece would be an ideal candidate for the vacuum chamber in order to try and impregnate those spaces within the piece, thus strengthening it in its entirety, rather than just the top and bottom.
Post by rockjunquie on Mar 16, 2023 12:21:09 GMT -5
Not "poo-poo'ing" what you've done...just thinking out loud. I can see the AR holding the slab together in order to cut preforms...but I'll be curious to see if the AR has any effect other than that. In my head, I imagine this material has space between the "parts" which is causing it to be brittle. I would think this particular piece would be an ideal candidate for the vacuum chamber in order to try and impregnate those spaces within the piece, thus strengthening it in its entirety, rather than just the top and bottom. For some reason- some how- that slabbette got crushed. It may just have been in the bottom of the bin. It has cracks that the CJ won't help. I could have used the CJ to help with porosity, but it would still have bad cracks. I would have to go back and fill the cracks with CA or AR. Evey time I touch it, a new piece breaks off. This was more out of curiosity than anything. I'm wondering if after the other side is treated if it will at least hold together. There is one small area that looks cabbable at this point.
Post by realrockhound on Mar 16, 2023 12:30:16 GMT -5
Nice big slab of Lucin variscite in there
Post by rockjunquie on Mar 16, 2023 12:44:53 GMT -5
Nice big slab of Lucin variscite in there Thanks, it's the best one I have. I don't think it needed stabilizing, but the matrix is pretty soft.
Post by jasoninsd on Mar 16, 2023 12:45:11 GMT -5
Post by realrockhound on Mar 16, 2023 12:50:17 GMT -5
Nice big slab of Lucin variscite in there Thanks, it's the best one I have. I don't think it needed stabilizing, but the matrix is pretty soft. Good call to stabilize. That stuff is so stinking soft. I cut a small cab and still got flat spots on the 3000
Post by rockjunquie on Mar 17, 2023 12:24:03 GMT -5
Well, Hell. I'm pissed. My oven was supposed to be here today. I was all ready to dry the slabs and test the temperature. My wrap teaching date was rescheduled, so now I have plenty of time to stabilize. NOT!!! No oven. It won't be here til Tues now. I ordered it on the 7th from Amazon Prime. What gives??
AND, the Art Resin didn't harden properly. I know I mixed it right right. I measured it.
Boo!
