fencejumper
Member since May 2021
Member is Online
Post by fencejumper on Mar 6, 2023 16:06:26 GMT -5
Starbond update: 😊 I have figured out a really good Way(90%) effective to seal slabs with starbond. Without the excess grinding, and multiple Application technique of 2part epoxy like art resin.
I soak the pieces in simple green and water 50/50 For a week Dry em off and blow dry em with compressed air.. I then hit them with the 100 grit dry wheel So all the hairlines appear clear as day.
I clean them off.. then put them under 250 heat lamp…. Fill the cracks with medium starbond, Leave them under the lamp For an hour Then come back and get any spots i missed. And hit it with the accelerator. Let cure for a day at least … 2 is better. Then I go 220.. 320… 600 Then cerium. Dont go back to 100 Cause it will rib the glue out.
Hope this helps.. I will show some pictures of finished pieces… Actualt the videos are better
Paul
rockbrain
Member since January 2022
Member is Online
Post by rockbrain on Mar 6, 2023 17:16:21 GMT -5
Looking forward to seeing the results.
fencejumper
Member is Online
Post by fencejumper on Mar 9, 2023 7:09:39 GMT -5
fencejumper
Member is Online
Post by fencejumper on Mar 9, 2023 7:12:55 GMT -5
cloudy day,,,i missed a few spots...but i am fine tuning as i go,,,,
fencejumper
Member is Online
Post by fencejumper on Mar 9, 2023 8:01:08 GMT -5
Post by jasoninsd on Mar 9, 2023 8:10:20 GMT -5
goldfinder
Member since December 2020
Post by goldfinder on Mar 9, 2023 13:18:59 GMT -5
Wow! That's an excellent shine Paul! It looked like that slab was pretty fractured before treating. Do you think you'll ditch the Art Resin for Starbond moving forward?
fencejumper
Member is Online
Post by fencejumper on Mar 9, 2023 13:22:31 GMT -5
I will upload a before picture… As far as grinding time and mess? The starbond seems wayyyy more efficient
rockbrain
Member is Online
Post by rockbrain on Mar 9, 2023 14:30:16 GMT -5
Saw that amazing slab on FB yesterday. So, did you only apply the Starbond to the cracks and nothing on the rest of the slab?
fencejumper
Member is Online
Post by fencejumper on Mar 9, 2023 14:42:13 GMT -5
Saw that amazing slab on FB yesterday. So, did you only apply the Starbond to the cracks and nothing on the rest of the slab? Yes Only to the cracks… The optical grade cerium gives a mirror shine Which makes me jolly
rockbrain
Member is Online
Post by rockbrain on Mar 9, 2023 15:33:30 GMT -5
I'd be jolly too! That shine is just ridiculous.
Post by MsAli on Mar 9, 2023 21:12:58 GMT -5
Holy crap Master!
Post by rockjunquie on Mar 10, 2023 15:22:57 GMT -5
With the cerium- after which wheel do you use it?
That polish is CRAZY!
eta
OK, I know you didn't use a nova wheel. Which GRIT do you use it after?
LOL! I see you answered it- never mind. Duh.
