Post by stefan on Mar 17, 2023 14:30:12 GMT -5
This was the last of my finished rock waiting for polish. I am all caught up as of today and have nothing waiting (except rough). THe mini sonic has done in 2 months what would have taken me probably 6 to 9 months to complete! First is some more Burro Creek agate. ![](https://res.cloudinary.com/da2qrvsnz/image/upload/v1679080910/ksxqoce5guavxp3fmsvf.jpg) Then some small Lakers. ![](https://res.cloudinary.com/da2qrvsnz/image/upload/v1679080973/p7rxadm98fr3znn7htqm.jpg) Other assorted What nots: Mozambique, Bahia, Missouri, Crazy Lace, Ocean Jasper (Sea agate), some Pet wood, and a local grey chert, and Ohio River chert ![](https://res.cloudinary.com/da2qrvsnz/image/upload/v1679081187/qwxnxji3dgip3pwxivdb.jpg) Some closeups Bahia Agate ![](https://res.cloudinary.com/da2qrvsnz/image/upload/v1679081246/reuuvamv9cdtrbo4lp6x.jpg) Pet wood (Can't remember where in Oregon it came from) ![](https://res.cloudinary.com/da2qrvsnz/image/upload/v1679081313/pnge7tdpywdikuj50jk1.jpg) Missouri Lace ![](https://res.cloudinary.com/da2qrvsnz/image/upload/v1679081346/ilvk9pljv7gups9h6vvy.jpg) And Mexican Crazy Lace ![](https://res.cloudinary.com/da2qrvsnz/image/upload/v1679081386/w6yfpez2tghllr9a2emw.jpg) Thanks for taking a peek!
khara
Member since September 2022
Post by khara on Mar 17, 2023 16:08:10 GMT -5
Great banded agates and petrified wood!👍
Post by jasoninsd on Mar 17, 2023 16:30:30 GMT -5
Another great looking group of polished beauties Stefan! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
chris1956
Member since July 2022
Post by chris1956 on Mar 17, 2023 16:41:02 GMT -5
Never get tired of looking at agates. Great job!
ashley
Member since February 2023
Post by ashley on Mar 17, 2023 16:47:43 GMT -5
stefanThose look amazing!! Awesome job and fantastic polish! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) I am using a minisonic at work and am having to learn it. I am used to the lot-o. What is your process and recipe ratios for the minisonic?
hoolligan1938
Member since January 2022
Post by hoolligan1938 on Mar 17, 2023 17:25:36 GMT -5
Looks like the mini-sonic is doing a great job. I'm a loto person but Your finish looks great!
Jim
jone
Post by jone on Mar 17, 2023 19:28:09 GMT -5
You’ve got some beautiful stones there, nice work! I hope I can get mine to look so nice!
Post by stefan on Mar 18, 2023 9:25:39 GMT -5
stefanThose look amazing!! Awesome job and fantastic polish! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) I am using a minisonic at work and am having to learn it. I am used to the lot-o. What is your process and recipe ratios for the minisonic? I have only been working with it since January, but I have learned a lot. Here is my "recipe" at this point. "Course" I am using 120/220. So far the best results for me have been 1 tablespoon borax and 1/2 tablespoon grit. Yes that tiny amount. I fill the barrel about 1/2 full of rocks and about 1/2 full of ceramics (usual fill barrel with water, add rocks and ceramics,dump off excess water, put on tumbler, run at full speed, add borax slowly, add grit slowly) I start the load running first to make sure it is rotating well. I fill to to just below where the neck meets the main body, I will add/ subtract until I have a good rotation. This step runs for 4 to 5 days (I don't recharge, but almost all my rocks are pretumbled in a rotary for several weeks) I follow the same clean out procedure between steps: dump out the rocks, ceramics, and rinse well then clean out the barrel, add rocks, ceramics, and a squirt (like 1/8 of a teaspoon) liquid dish soap, let run for about an hour, clean out again. "medium" Using the same media, I follow the same fill procedure (water rocks, ceramics, dump off excess) I add 1 tablespoon borax, and 1/2 tablespoon 500 grit. I was using SiC, but recently switched to 500 AO and like it much better. This runs for 4 days (or longer if needed). I will take a rock out after 4 days and I should start to see a shine, if not then it goes in for another day, or 2. I use the same rinse cycle as before. "Pre polish" I run a pre-polish stage with 1/2 tablespoon of borax, and 1/2 a teaspoon of tripoli (around 1200 to 1400 grit). This goes for 3 to 5 days. The rocks are pretty shiny at this point. I do a cleanout like above, but add 1/2 tablespoon of borax to the soap) "Polish" I have a separate barrel and ceramics for polish. Prep the rocks the same way. I use 1/2 tablespoon of borax and 1/2 teaspoon of AO polish (kingsley North, or Rock Shed, both are great polishes). This runs for 5 days. I clean out like above and set up for burnish (I do a soap and borax wash like for pre-polish) "Burnish) Prep the rocks like above and add 1 tablespoon of Borax. This runs about 4 to 6 hours (longer is fine and I have done overnight). I add dish soap to the mix and run that for about 30 mins, then dump it all out and rinse very well. Phew that seems like a lot of work. I have used more grit and polish, but I end up with the same results, and have left over grit (especially in the 120/220 and 500 steps). The times are not set and I check the load once a day. THe Mini soic does not use a lot of water and I usually don't have to add any (except at the very start of the cycle, where I will watch it run for 5 minutes, and spray the load if I see the borax not dissolving. It is very important to clean the lid between stages, I have found grit stuck to the lid on more than 1 occasion. I run the speed at full for the 120/220 stage, after that it depends on how the load is rotating. I find that I'm running it at about 80% for the pre-polish and polish stages, and about 60% for burnish. My polish barrel is a little smaller than the other barrel, I would guess about 10 to 15 less chunks of medium ceramics. I use 3 sizes of ceramics. 5/16" and 3/16" cylinders, and 5mm balls. They get into even the tightest spots. Hope that gives you a launching spot!
ashley
Post by ashley on Mar 18, 2023 14:32:54 GMT -5
stefanWow thank you so much for taking the time to help me! Thank you!! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
jone
Post by jone on Mar 18, 2023 15:53:16 GMT -5
stefan This is the first "recipe" I have seen for the mini-sonic besides what is in the manual (which no one ever seems to follow anyway). This is very helpful! I started with Rob's (Michigan Rocks) method that he uses for the Lot-O which was in one of his videos. I am tweaking it as I go but I have only finished one batch so far. Thanks for sharing your experience. Your method seems a little longer duration on each stage, uses borax for all stages, less grit for 120/220 stage, and adds a pre-polish step. You also are using more ceramics, I think. Great food for thought!
Post by stefan on Mar 18, 2023 16:37:09 GMT -5
Thank you all. Yes my recipe is very different. I too started with Rob's Lot-o recipe, but was not getting the results I wanted. I started running longer and saw improvement, but was still having left over grit. Started running less grit, and again saw improvement, but still wasn't what I expected. Once I added in my pre-polish stage and the Borax it all started to come together. I was frustrated with the lack of recipes for the mini sonic as well. I think the only one I found that was close was from Drummond Island Rocks, but even his just wasn't working great for me.
wedger
![*](//storage.proboards.com/forum/images/stars/star_orange.png)
Member since March 2023
Post by wedger on Apr 12, 2023 11:50:42 GMT -5
Is this with an MT-4 or one of the larger units?
Post by stefan on Apr 14, 2023 10:26:28 GMT -5
Thats a MT-4. I am so impressed with that tumbler!
jone
Post by jone on May 27, 2023 8:50:23 GMT -5
stefanI have been using your "recipe" for the MT-4 as above with a couple of minor modifications (1000 AO instead of tripoli, for one). The last couple batches, I'm trying to use shorter fixed duration times to see if I could speed up the process. Last batch was 4 day for all stages and came out great. Currently I have a load in there that I'm doing 3 days for all stages. I'll let you know how it looks. Thanks again for your help!
rockbrain
Post by rockbrain on May 27, 2023 22:16:49 GMT -5
Nice looking stones! I love my minisonic. I do similar to yours but usually run each stage 3 days.
Post by velodromed on May 28, 2023 15:15:15 GMT -5
The orange Bahia agate and the crazy lace at the bottom are amazing! All of them are actually, nice work!
rocknewb101
Member since October 2022
Post by rocknewb101 on May 30, 2023 8:44:33 GMT -5
Beauties! Great job on those!
Post by victor1941 on May 30, 2023 9:18:49 GMT -5
Great polish and especially like the stones that have both color and banding. Great directions for the mini-sonic!
jone
Post by jone on Jun 3, 2023 11:07:59 GMT -5
Here’s the stefan recipe with 3 days for all stages ![](https://res.cloudinary.com/djj7v3jik/image/upload/v1685808304/rtedzngmgjg4zkiiothj.jpg) Leopard skin jasper, petrified wood, and Bahia agates - I think they turned out nice - good polish! Love the mini-sonic!
dug
Member since March 2022
Post by dug on Jun 21, 2023 19:51:55 GMT -5
stefan Any particular reason for using tripoli as a pre-polish? I've only every used AO, so I'm curious how tripoli might be different. Thanks!
