dfh83
Member since April 2023
Post by dfh83 on Apr 26, 2023 8:53:21 GMT -5
Hello i just have a stupid question....i just purchased a highland park k-12 flat lap and it doesn't have a arbor hole to attach a dics....so how would i go about attaching something to it?
Help
Apr 26, 2023 9:10:40 GMT -5
Post by MsAli on Apr 26, 2023 9:10:40 GMT -5
I've never used on so I could be wrong, but I believe you lay the disc on the machine ? You should be able to confirm this on the Highland Park website
Help
Apr 26, 2023 9:26:30 GMT -5
via mobile
Post by manofglass on Apr 26, 2023 9:26:30 GMT -5
dfh83
Help
Apr 27, 2023 7:21:53 GMT -5
via mobile
Post by dfh83 on Apr 27, 2023 7:21:53 GMT -5
this one definitely doesn't have a hole or a stud in the middle of the disc....its pretty old the body of the machine is cast iron....
dfh83
Help
Apr 27, 2023 7:31:07 GMT -5
Post by dfh83 on Apr 27, 2023 7:31:07 GMT -5
No it's spins around and around... It's just a very early highland park model from what I have gathered...
dfh83
Help
Apr 27, 2023 8:26:05 GMT -5
Post by dfh83 on Apr 27, 2023 8:26:05 GMT -5
I've never used on so I could be wrong, but I believe you lay the disc on the machine ? You should be able to confirm this on the Highland Park website I had thought about that.....but I also thought it would just throw it like a frisbee lol
Help
Apr 27, 2023 9:14:49 GMT -5
via mobile
Post by manofglass on Apr 27, 2023 9:14:49 GMT -5
Use a magnetic disk
Help
Apr 27, 2023 10:33:02 GMT -5
Post by aDave on Apr 27, 2023 10:33:02 GMT -5
Hello i just have a stupid question....i just purchased a highland park k-12 flat lap and it doesn't have a arbor hole to attach a dics....so how would i go about attaching something to it? I've only used a flat lap once, and it didn't have discs. Grit was poured directly on the surface of the wheel. Once a grind was done, the wheel (and the rock) was washed off and the next grit size down was used. You're also going to need some type of water source for that. I just found this video. It's not great as there isn't any verbal instruction, but you'll see the user go through his process. Just remember to keep your material moving across the wheel so the wheel doesn't form an irregular surface. He used a spray bottle for water. It also looks like there are drip sources available in the aftermarket.
dfh83
Help
Apr 27, 2023 14:03:40 GMT -5
Post by dfh83 on Apr 27, 2023 14:03:40 GMT -5
Hello i just have a stupid question....i just purchased a highland park k-12 flat lap and it doesn't have a arbor hole to attach a dics....so how would i go about attaching something to it? I've only used a flat lap once, and it didn't have discs. Grit was poured directly on the surface of the wheel. Once a grind was done, the wheel (and the rock) was washed off and the next grit size down was used. You're also going to need some type of water source for that. I just found this video. It's not great as there isn't any verbal instruction, but you'll see the user go through his process. Just remember to keep your material moving across the wheel so the wheel doesn't form an irregular surface. He used a spray bottle for water. It also looks like there are drip sources available in the aftermarket. well i think i just found the answer to my question....now where would i find one of those aftermarket drip systems...ive looked around but cant find anything suitable? I would like to keep as original looking as possible....
Help
Apr 27, 2023 23:12:52 GMT -5
Post by aDave on Apr 27, 2023 23:12:52 GMT -5
dfh83I don't know how "original looking" you'd be able to keep it when it comes to a water supply, as there might be a good chance a user for one of those original machines just sprinkled or sprayed water as needed. I don't really know, as I'm guessing. That said, you could set up something like this: kingsleynorth.com/flex-cooler-with-pump.html. All your water source might need to be with something like this would be a five-gallon bucket.
