Post by liveoak on May 3, 2023 10:56:59 GMT -5
I finally finished this last night after a couple of tries.
It's a beautiful cab I traded out with the "roaming wire", and I believe it came from Tela (thanks Tela ). It's a "Chrysocolla Copper Complex".
I'd never done a wrap with beads before, so I tried to come up with something that wasn't too complicated. I think this one fits the bill.
But then of course there is the lesson l had to learn.
As I mentioned before I like to tumble my wraps after LOS, and when I first did this one, I had a rude surprise.
I found out that not all beads that look like copper are copper.
I BRIEFLY thought, well it's different, but it might still work.
Then I showed it to Tom, and his comment was how it looked like a row of teeth on the bottom of the cab
So, off to Etsy to buy real copper beads.
In the end, I like the new beads with the ridges as the LOS defines them nicely.
Anyway, here it is - thanks for looking,
Patty
Post by hummingbirdstones on May 3, 2023 12:23:36 GMT -5
liveoak Patty that wrap turned out gorgeous! Sorry you had to learn that little lesson, but now you'll never forget!
Post by liveoak on May 4, 2023 5:59:24 GMT -5
Thank you Robin hummingbirdstones . I am pretty happy the way it came out & heck I had a second try to make sure
But you are very right I won't ever forget about the beads !
Patty
ashley
Member since February 2023
Post by ashley on May 4, 2023 9:00:04 GMT -5
Awesome wrap Patty!
Post by liveoak on May 4, 2023 9:34:35 GMT -5
Post by rockjunquie on May 4, 2023 10:52:41 GMT -5
I like that a lot, Patty liveoak!! The copper is perfect and I must say the copper beads are much better than the quartz.
khara
Member since September 2022
Post by khara on May 4, 2023 14:27:28 GMT -5
I like it. The copper and beads look nice with the chrysocolla.👍 I made a handful of cabs back during the Thunderegg cab contest. My intent was to keep some matrix in each cab and where possible a raw edge. One of them was a small triangle with matrix at the base and clear agate the rest of the way. My husband said it looked like a removed tooth. Pretty much I can’t look at that cab anymore in a good light. But, it was good practice!
Post by susand24224 on May 4, 2023 15:23:11 GMT -5
Patty, as I scrolled down the screen on my mini-laptop, I was wondering how the cab would "ground." Then I got to the beads and it was perfect! The beads (teeth) ground it perfectly. What looked confused turned into a masterpiece. Nice job.
Post by liveoak on May 4, 2023 15:35:55 GMT -5
The copper is perfect and I must say the copper beads are much better than the quartz. Thank you Tela - but it took a nice cab to start with ! I like it. The copper and beads look nice with the chrysocolla.👍 I made a handful of cabs back during the Thunderegg cab contest. My intent was to keep some matrix in each cab and where possible a raw edge. One of them was a small triangle with matrix at the base and clear agate the rest of the way. My husband said it looked like a removed tooth. Pretty much I can’t look at that cab anymore in a good light. But, it was good practice! Yup, know exactly what you mean - it's funny how someone else can see something very different.
Unfortunately then you can't stop seeing it either !
Patty, as I scrolled down the screen on my mini-laptop, I was wondering how the cab would "ground." Then I got to the beads and it was perfect! The beads (teeth) ground it perfectly. What looked confused turned into a masterpiece. Nice job. Thank you Susan.
I still feel like I'm very much starting out with the wire wrapping,
so when/if I pull one off that's my own design (that I think looks good), I feel really accomplished.
Thanks for noticing
Patty
Post by liveoak on May 4, 2023 16:41:36 GMT -5
I realized I should have shown that this is what the beads looked like when I did the first wrap.
The tumbling after my patina, took the copper color away I never considered that they were copper COLORED glass beads.
But I know now !
Patty
Post by rockjunquie on May 4, 2023 17:06:06 GMT -5
But I know now !
Patty
I thought they were quartz! I've gotten a lot of beads that claimed to be raw copper and weren't. Now, I dip them in LOS before I use them.
Post by liveoak on May 4, 2023 17:14:45 GMT -5
Now, I dip them in LOS before I use them. That's a great idea.
Thanks for that.
Patty
Post by rockjunquie on May 4, 2023 17:16:18 GMT -5
Thanks for that.
Patty
A little late, I guess.
Post by drocknut on May 23, 2023 21:43:20 GMT -5
Great job on the wrap, glad you were able to find real copper beads to replace the fakes.
